6BG6G SE advice needed.
Old 7th January 2012, 09:48 PM   #1
Hojvaelde is offline Hojvaelde  Denmark
Default 6BG6G SE advice needed.
Hello
I have collected parts for what I hope will be a happy marriage.
Output tubes: NOS 6BG6G from Emerson
Power traffo provides 425-430 volts when it is well stabilized and with 125 mA load.
Output transformer: 5k with 20% UL clamp (max. 90 mA).
Is this output transformer suitable for this tube (which is 6L6G with hat)?
Self biasing running with 50 mA.
I have made one amplifier with 6GB6G before, but only with 280 volt and in triode mode.
Benny
Old 8th January 2012, 03:53 AM   #2
Hi again
Stupid me. G2 may only get 250 volt. No UL only pentode. Back to schematic again.
Benny.
Old 8th January 2012, 04:36 AM   #3
Eli Duttman is offline Eli Duttman  United States
UL may be doable. You will need to keep screen dissipation under control. Put 1.5 KOhm resistors in series with the screen grids. Use meter matched carbon comp. parts and mount them right at the sockets. You get double duty from the CC resistors. They act as stoppers and current limiters.
Eli D.
Old 8th January 2012, 04:54 AM   #4
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Sylvania data sheet says 350v for screen, with 3.2 watts dissipation.
jeff
6BG6G SE advice needed.Hide this!Advertise here!
Advice needed on new 6L6 ro 6V6 SE or SET build GloBug Tubes / Valves 39 23rd November 2011 05:22 PM
SE amplifier advice.. Dxvideo Tubes / Valves 11 23rd April 2011 01:50 PM
Needed - Advice on tubelab Simple SE build Salsero Tubelab 2 30th December 2009 07:51 PM
experimental 6L6G / 6BG6G amp design brainstorm chromal Tubes / Valves 34 21st March 2009 12:45 AM
Anyone build/use 6BG6G? kegger Tubes / Valves 12 28th February 2007 09:12 AM
Copyright ©1999-2017 diyAudio
