Old 11th January 2012, 08:13 PM   #31
HP8903B is offline HP8903B  United States
Just to make sure I understand right.
The computer option has very low distortion, much lower than the function generator.
Is this true only in sine wave ?
The function generator generates square waves much better than the computer option.
Old 11th January 2012, 08:42 PM   #32
Hollowstage,
Could you tell me more about the Leader models that you mentioned.
Seems like the Leader LAG-120B is comparable to the HP 209A.
Old 11th January 2012, 08:52 PM   #33
veteran is offline veteran  Poland
veteran's Avatar
You're right. This is the 5kHz square wave generated by my sound card
Simple audio solutions
blog.unisonus.com
Old 11th January 2012, 08:58 PM   #34
haha, that's not square at all.
Old 11th January 2012, 09:28 PM   #35
What do you guys think of this Leader LAG-120B on ebay:
LEADER LAG-120B AUDIO GENERATOR | eBay
What are some potential problems with this unit and how likely ?
Old 11th January 2012, 09:30 PM   #36
I've been using a Radford LDO4 [and others] for years. Low distortion, good square wave and an oscillator stop facility.
Old 11th January 2012, 09:32 PM   #37
nigelwright7557's Avatar
I picked one up cheap on ebay.
Has worked well for 5 years now.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 11th January 2012, 09:42 PM   #38
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Ringing (not that much as in #33) is inherent in digital synthesis. The DDS instrumentation ones do filter the ringing but they lack in rise time as you push them higher to their limit VS analogue ones due to LPF. Talking under 500$. Full rise time is still available on their TTL output which is not filtered and you will be able to see the inherent ringing. Very good stability in PPM over the years and great functionality is the other side of the coin. Very good signal quality is offered by TTI-Thandar made in UK in medium to low prices (relatively, as generators go), they do good analogue still.
If using soundcard FFT for THD which is great for that, there are many cheap enough good solutions for nicely shaped square waves up to 1MHz from instruments that go to 3 or 5MHz. Their THD won't be better than -50dB though.
Old 11th January 2012, 09:45 PM   #39
You mean the Leader LAG-120B ?
Old 11th January 2012, 10:05 PM   #40
HollowState's Avatar
Hollowstage,
Leader is OK, Made in Japan, but is probably the best if the Asian imports. I've never owned one, but I have had some of their other stuff.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
spdif signal generator Nikon1975 Digital Source 3 23rd August 2010 02:18 AM
Signal Generator Help Bengali Equipment & Tools 12 24th April 2008 04:20 PM
looking for a signal generator Ahmad_tbp Solid State 21 8th September 2006 11:37 PM
DIY signal generator? Loial Parts 13 19th September 2005 10:36 AM
signal generator help hizz_eye Solid State 2 3rd March 2005 10:25 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
