| diyAudio Sponsor | ||
#31 |
diyAudio Moderator Emeritus
You must remember to rotate the mains transformer 90 deg compared with the opt's, otherwise hum will be magnetically coupled.
#32 |
$60 bucks a pop is not cheap. EDCOR has better for $27.00
#33 |
#34 |
I will make a thread when I get around building it in a while.
#35 |
#36 | |
Single-Ended Tube Amp Kit |
#37 |
If I want Norah to sing for me in my living room, I use a 45 SE through full range speakers. If I want to fend off the bassers in the neighborhood, Metallica through 125 WPC of P-P power into 96 db speakers does the job.
For the best all round compromise, a P-P 300B amp with a touch of intentional imbalance will sound a lot like a DHT SE amp until you crank it, then its P-P punch and dynamics come through. None of these are good choices for a first amp, especially when the builder has tubes and transformers for a SE EL84 already. An SE EL84 can be made to sound quite nice too.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#38 |
My preference is always with a good Class A PP amplifier.
Schade is a good compromise between SE & PP. Generally far more punchy than a traditional SE. I will not recommend the RH84 as I consider it a poor implementation of the concept - but something along those line should do nicely. Shoog |
#39 | |||
#40 |
Class A PP triode zero feedback is definitely the minority option for PP. I dare say that most of the popularity of SE is directly due to the fact that almost all PP amps are heavily biased into class B and use pentodes. Apples and Oranges as far as I am concerned.
Most people endlessly paw over details of every single component in their SE builds and then declare them superior to the Williamson or Mullard PP amp made from crappy parts !! The worst thing is that most of them don't even understand why the comparison is so unfair. Shoog |
| Push-Pull from Stereo SE amp | benproiii | Tubes / Valves | 6 | 28th July 2011 05:36 PM |
| tony's 6LU8 push-pull power amp build | Tony | Tubes / Valves | 6 | 15th February 2011 09:07 AM |
| Se Amp with Push Pull Transformer | DougL | Tubes / Valves | 19 | 5th November 2009 05:33 AM |
| Looking to build a 25-30 WPC Push Pull amp - Need Help | SigloOne | Tubes / Valves | 58 | 6th November 2008 01:04 AM |
| Push Pull Output tranies for SE amp? | targeteye | Tubes / Valves | 7 | 20th August 2008 05:51 AM |
| Page generated in 0.10109 seconds (87.04% PHP - 12.96% MySQL) with 10 queries |
