What amp to build? Push Pull, SE? thoughts? - Page 2 - diyAudio
Old 7th January 2012, 12:18 AM   #11
Here is another candidate:
http://i263.photobucket.com/albums/i...5StereoAmp.gif
From this site:
Electronics Projects - Vacuum-State Electronics
Old 7th January 2012, 12:28 AM   #12
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
What kind of output transformers do you have?
Tubes are cheap. Transformers are more expensive.
The Devil is not so terrible as his math model is!
Old 7th January 2012, 12:40 AM   #13
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
Why not buy a 12AT7 and build the RH84SE amp? Lots of people have built it and are pleased with the results.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 7th January 2012, 01:07 AM   #14
kmaier is offline kmaier  United States
kmaier's Avatar
I'm leaning towards Wavebourn's response... look at what OPTs you have or what you're willing to spend on a pair. That will dictate your amp overall... and you should consider the output tube and stage topology at the same time.
Oddly, 45 triodes are a bit less expensive these days... for a couple watts, it's difficult to think you could possibly do better. And at the same time, consider what you are going to be driving as a speaker... that also influences what you would or could be happy with.
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 7th January 2012, 01:34 AM   #15
Wavebourn's Avatar
4P1L
Old 7th January 2012, 01:57 AM   #16
kmaier's Avatar
Originally Posted by Wavebourn View Post
4P1L
I can't argue with you on this one... I just don't have any of them (4P1L) to play with. I do have an extensive collection of 45 triodes... so I will sign up for being well versed on the 45. What differences do you perceive between the 45 and 4P1L?
Regards, KM
Old 7th January 2012, 02:25 AM   #17
No offense, but you all just go off on your own tangents all the time, don't you.
OP has EL84, 12AX7.
No mention of 12AT7, 45s, 4P1L, blah, blah, blah.
Please stick to the subject at hand.
Old 7th January 2012, 02:32 AM   #18
Bad link. Here is the correct one:
Old 7th January 2012, 03:16 AM   #19
aardvarkash10's Avatar
in addition, unless you want ot spend up on opts, you are stuck with the opts you have (presumably SE).
Just build. How much research do you need when you have all the major components and there are only two or three workable combinations to use them?
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 7th January 2012, 03:17 AM   #20
As Waveborn asked, "what kind of OPT's do you have"? SE and PP opt's are not the same!
tony's 6LU8 push-pull power amp build AJT Tubes / Valves 28 6th September 2015 01:07 AM
Push-Pull from Stereo SE amp benproiii Tubes / Valves 9 2nd April 2014 11:17 PM
Se Amp with Push Pull Transformer DougL Tubes / Valves 19 5th November 2009 05:33 AM
Looking to build a 25-30 WPC Push Pull amp - Need Help SigloOne Tubes / Valves 58 6th November 2008 01:04 AM
Push Pull Output tranies for SE amp? targeteye Tubes / Valves 7 20th August 2008 05:51 AM
Copyright 1999-2017 diyAudio
