diyAudio Sponsor
Old 4th January 2012, 06:20 PM   #1
Default Fixed Bias question
I have a voltage divider on my B+ which gives me 70 volts.Could I use this to make a negative bias supply and if so, has anyone got a basic schematic or explanation on how to do it.
Old 5th January 2012, 01:44 AM   #2
Enzo is offline Enzo  United States
Not without making some sort of DC/DC converter.
Easier to tap off the B+ AC supply and make bias from that if there is no bias winding.
Old 5th January 2012, 08:14 AM   #3
Send a message via Skype™ to Wieslaw Lipowsk
Here it is:
Old 5th January 2012, 10:23 AM   #4
You need a negative voltage for the bias supply rather than positive you could get out of your B+.
Old 5th January 2012, 06:02 PM   #5
Thanks for the help...I also have a small toroidal transformer that gives me 22vct.Could this be used to build a negative supply?
Old 5th January 2012, 06:45 PM   #6
You could try it. If the negative voltage isn't high enough, you can use 0.5K/7W resistors at the power tubes cathodes (with some 220uF caps across them). This way you could have half fixed and half cathode biased amplifier.
However, I' d make the bias supply the same as in the picture above.
Old 5th January 2012, 11:39 PM   #7
Current demand on bias is tiny, so if your 22v transformer is not enough, you could make a voltage doubler for it.
EL84 fixed fixed bias razorrick1293 Tubes / Valves 3 20th November 2011 03:33 PM
Fixed bias design question Rob11966 Tubes / Valves 15 2nd May 2009 11:30 PM
Finding bias point in PP fixed bias beamnet Tubes / Valves 14 7th December 2008 01:25 PM
quick question on fixed bias sorenj07 Tubes / Valves 3 6th August 2007 02:26 PM
Page generated in 0.10008 seconds (72.13% PHP - 27.87% MySQL) with 11 queries
