| diyAudio Sponsor | ||
Hey
I have received some TV tube, which I have sorted. Most I have discarded or placed into stock. There are some who teases me a little. Here they are left over: EF91 ( 6AM6 ) sharp cut-off but audio? 6AK5/6AK5W some audio. EC86 (6CM4) Is almost sure of audio properties PC86 (4CM4) See above PC88 (6DL4) Maybe PCC189 (7ES8) No PCC88 (7DJ8) Hm.. PCC85 (9AQ8) I think this is OK EF184 (6EJ7) Should be OK Anyone know them before I start TubeCAD? Regards Benny |
#2 |
At college in 1966/7 I built a single valve radio and after that a single valve audio amplifier both using the EF91. Sounded good.
#3 |
According to MJ books (and some simulations / breadboarded test circuits I did) EF184 makes a very good tube for a pentode CCS.
Greetings, Andreas PS. If you plan to get rid of the 184's, I would give them a new home^^ |
#4 | |
I know the ef184 which is OK for guitar amps and current sources and if you design with care it could also be good for hifi. I'd use the 6AK5 and that's it.
Good sound comes and goes. |
#5 |
I have a working EF184 model for LTSpice, if needed.
Greetings, Andreas |
#6 |
Benny,
Even the PCC189/7ES8 has some audio applications. The variable μ has little impact in cathode follower service. Also, use in the 1st gain block of a phono preamp can work out, as the plate current variations are quite small. The thing NOT to do is plug an 'ES8 into a 'DJ8 "hole" and expect all to be well.
Eli D. |
#7 |
Used all of them in temporary designs.
Except the xCC189 since that is variable-µ valve. But even that can be operated in the more or less linear region. Just have a look at the curves and you see if you can use them. Biggest problem is microphony since most of these tubes were used in tuners where low frequency interference wasn't a problem. So you need huge batch to sort the good ones out. I have far over a hundred EF80 and nearly all have such a strong microphonic effect, that every step in the room is a problem. Even <> EF800 do that.
Терпенье и труд все перетрут
#8 |
EF91 (Z77) was used in some EMI professional tape machines.
#9 |
PCC88 is the same as 6DJ8/6922 with a different (0.3A, ~7.2V) heater...
#10 | |
Tinkerer
I have never noticed that with 3 brands of EF80 (Mullard, 2 kinds of Ultron). Maybe because I use them in high current regions? Maybe cause I use them as triodes? |
| 60 x 6s45p-e Russian tubes on sale! Special price!!! | Ippolit | Vendor's Bazaar | 1 | 17th November 2011 02:23 PM |
| Burn in small signal tubes? | karsten21 | Tubes / Valves | 4 | 31st October 2011 06:34 PM |
| small-signal (small-power) fast switching complementary transistors | Lola Luna | Solid State | 3 | 8th April 2010 07:51 PM |
| Small-signal (or small power) pentode that can handle 400V (or more)? | GordonW | Tubes / Valves | 12 | 13th June 2008 02:07 AM |
| Information needed on RCA SPECIAL RED TUBES | Original Burnedfingers | Tubes / Valves | 2 | 27th April 2007 04:05 PM |
| Page generated in 0.09868 seconds (88.98% PHP - 11.02% MySQL) with 11 queries |
