I've worked on the original and the Audio Marginal clone as well. Schematics are available on the net.. (Do not post them here without the author's permission!)
Given the very high voltages present I recommend you read the thread on safety, and I am assuming that you are not a total newbie..
I recently completed my own GM70 design and at plate voltages of 1kV and above there are interesting issues relating to corona discharge, insulation, capacitor sourcing, etc..
The Ongaku design is now over 20yrs old and not quite cutting edge in the high voltage tube world, but it is a good sounding design IMHO.. The tube bridge rectifier is quaint, but probably more trouble than it is worth. I'd use a hybrid bridge or go solid state..
Hi reteP2k,
Any single End Class A1 or A2 amplifier based on a 211 tube will give wonderful sound if properly engineered.
Mine works nicely, finnshed in late 90's from my own design, gives no hum at all, fantastic clean bass. mid and highs on my Castle Chester loudspeakers (87bD per Watt).
You may have a look at my site at (sorry, it is in Portuguese, but you may use Google translator):
Diagramas e detalhes adicionais - Suna
