| diyAudio Sponsor | ||
Hi everyone,can someone point me to the right direction hence I am struggling (new to this thing)
to identify this actual tube pins (6N16B) there are 8pins, its been mixed up ,this is a double triode I think for me it look easy in the diagram but seeing in the actual is very difficult for me... I can not figure out which is pin one and so on, your help is very much appreciated thanks in advance, I need to replace this (6N16B) my amps VINCENT SP-331 |
#2 |
Pin identification is always hard on these flying lead Russian tubes. If you cannot see the "slightly" wider gap between pin 1 and pin 8, then find the two leads that are continuous. These will be the filament, pins 4 and 8. These will be the only two continuous leads so you can figure out the rest from identifying these. There should be a hint of red color, or a bump in the glass, between pin 1 and pin 8. Remember the pins are numbered counter clockwise when looking at the bottom. Good luck.
Matt Last edited by mwiebe; 31st December 2011 at 02:43 PM. Reason: addition |
#3 |
Hi Matt, thank you for the TIPS, I'll try to do this listen would that be possible to supply the filament even in a low voltage to make sure that glow, and not to damage the tubes??? Tony
#4 |
diyAudio Moderator Emeritus
#5 |
Apparently I have to write something in this box!
#6 |
Dhaen,
Yes my mistake, the 6N16B pins are numbered clockwise, sorry for the mistake. Tony, There is no need to light the filament, just use a continuity tester to find the filament leads. Using 12V or below for a short time I doubt you will hurt anything. Matt |
#7 |
Well no body is perfect I would say LOL...anyway Matt, Dhaen,thank you for the help I really appreciated it, Tony
| Emission - Double Triode | Bone | Tubes / Valves | 4 | 5th July 2010 11:45 AM |
| what double triode is less microphonic ? | inertial | Tubes / Valves | 49 | 19th December 2008 09:21 AM |
| Using one half of double triode | cs | Tubes / Valves | 8 | 1st March 2006 04:10 PM |
| a single double triode and two chanel? | killerfishes | Tubes / Valves | 2 | 14th June 2005 12:16 PM |
| Heating only one half of a double triode | bequerel | Tubes / Valves | 9 | 28th October 2004 04:43 PM |
| Page generated in 0.09103 seconds (73.45% PHP - 26.55% MySQL) with 11 queries |
