diyAudio Sponsor
Old 30th December 2011, 04:41 PM   #1
Default HEllo and a few suggestions please
Hello everybody,
I am very new to this forum. Well actually I joined about two years ago, but got distracted by AK. I have just refound you folks.
I am a tube amp builder wanabe. I have built about 20 amps, but all from predesigned schematics and with help from friends at ak. I just figured out how cathode bias works this morning - my point is I am a bit slow and teaching myself as I go.
I am currently working on a project made from leftovers and scraps. I have a pair of Pilot el84 pp OPT,s and a PS from a Zenith 7D31. I hae found several schematics that might work, but I was wondering if anyone hada suggestion of a favorite for this configuration.
The PS puts out about 730v(supposed to be 660 @ 117VAC). I have a pile of drivers(12ax7's, 6u8a, 7199.s 6eu7's, etc)
So, anyone have a suggestions. Oh, the OPTs, even though they are pilots, area little small. PRobably about the same size as the oes on the magnavox 93** chassis'.
TIA!
MArk
AKA cricket
Old 30th December 2011, 06:11 PM   #2
The power trafo will droop under load.
You will do fine using the Pilot O/P trafos, IF you triode wire the "finals". The reduced power O/P of triode wiring leaves magnetic headroom for a GNFB induced low freq. error correction signal to work, without causing core saturation.
There are many good options available. Of course, I'll "push" a design I'm associated with. The "El Cheapo" schematic I've uploaded will work, without parts value changes, using any 6V6 family O/P tubes. EL84 family tubes will work, with a cathode bias resistor value change.
Eli D.
Old 30th December 2011, 07:55 PM   #3
My power supply circuit will obviously be different. What can you say about those CC circuits? I have never seen or heard one. Interesting ide for sure.
Here area few pics of my build so far
Old 30th December 2011, 08:44 PM   #4
boywonder's Avatar
The baby Huey is another popular choice. PP EL84, 12AX7 LTP, UL wired.
EL84 Amp - Baby Huey
The thread only has about 1200 posts.........better brew some coffee.
...another is Poindexter's 6GK5/6V6 music machine. Triode wired 6V6 PP for about 6W output.
Do a search here for music machine.....
and finally, SY's red light district EL84 PP Pentode wired.
The Red Light District - another PP EL84 amp
Old 30th December 2011, 08:45 PM   #5
A constant current sink (CCS) in the tail of a differential gain block is "killer". Symmetry is forced upon both O/P signal phases. In "El Cheapo" the CCS "glues" the driving signal and the NFB signal together.
Looks like you're setting up for a 5 V. tube rectifier. Obvious 250 mA. capable types (in descending rail voltage order) are the 5AR4, the 5U4GB, and the 5R4. Make the 1st cap. of a CLC filter 20 μF. and you will be safe to experiment with all 3. Settle on the type that brings the B+ rail voltage in "perfect". The 5U4GB draws 3 A. of filament current, unlike the 2 A. of the other 2 types. Make sure the power trafo can take the strain. BTW, use the "potato masher" 5R4 variant, as other 5R4 varieties might arc over.
Eli D.
looking for suggestions for my first one moshik008 Multi-Way 5 5th June 2009 05:09 PM
Suggestions? billbeau Chip Amps 5 29th October 2008 03:49 PM
Suggestions please!!! safetyman Pass Labs 1 14th September 2005 07:28 PM
Any suggestions jaybird Multi-Way 3 15th January 2004 09:12 PM
3-way suggestions seangoesbonk Multi-Way 9 22nd June 2002 12:22 AM
Page generated in 0.08418 seconds (86.18% PHP - 13.82% MySQL) with 11 queries
