Help on transformers please
Old 30th December 2011, 02:18 PM   #11
Sgkho249 is offline Sgkho249
Originally Posted by boywonder View Post
The photobucket link doesn't work.......
Please try again,
http://i697.photobucket.com/albums/v...DSC_0057-1.jpg
Old 30th December 2011, 02:26 PM   #12
Troncones is offline Troncones  United States
Troncones's Avatar
boywonder: You were very helpful with this one. Like the glasses.
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 30th December 2011, 02:40 PM   #13
boywonder is offline boywonder  United States
boywonder's Avatar
Originally Posted by Sgkho249 View Post
No idea on that one....perhaps a google search. Is it from a solid state amp/preamp?
Thanks Troncones! Please feel free to chime in with suggestions......
Old 30th December 2011, 03:47 PM   #14
Troncones's Avatar
My suggestion would be keep them. Once you go down the path of DIY tube audio there's no such thing as having too much iron on hand.
Old 8th April 2013, 03:54 AM   #15
Hello boywonder,
Sorry to bring up an old post. i am intending to build a SET poweramp with 2x el3n/ 2x 6j5gt/ ez81 rectifier tube. PT parmeko 350-0-350 CT 0.18amp filement 6.3v 0.5amp. rectifier 5v 3amp, parmeko chock 10H 180mamp.
question is will the amperage be enough for all the tubes, also can i use the rectifier tap of 5v 3amp to run on the ez81.
attach a schematice
Thanks in advance....
Please be paitent with me as this is the first tube amp im building
Old 8th April 2013, 10:05 AM   #16
45 is offline 45  Italy
45's Avatar
The amperage will be not enough for powering all filaments. You could use a bridge rectifier for the 5V secondary and use it to supply the EL3n filaments. The 6.3V/0.5A could be stretched to power 6J5's however it would be a bit bizzarre using AC for signal tubes and DC for output tubes. Still you would need 6.3 1A for the EZ81. Older types like EZ40 and EZ41 (very similar to EZ80 and 90) were specified with both AC and DC filament supply. However I have never seen this for EZ81.
Old 8th April 2013, 03:31 PM   #17
boywonder's Avatar
You could always use a separate 6.3V filament transformer......
Any particular reason for this circuit?
Your output transformer is PP, this is SE; I imagine that you are planning on buying SE output transformers?
Do you already have EL3n's? Those tubes look like they need some crazy sockets.....
Old 8th April 2013, 03:56 PM   #18
Ok thanks, 6.3v how much amperage should I go for so that it will have enough current to run 2x el3n and 2x 6j5 and rough guide on the price please.
Really have no ideal but I heard these el3n over at a friends place and I like it. So I thought with the iron I have I could try and build a set amp. Almost done with all the items I needed for these project. And realize that the amperage is only 0.5a not enough to provide for the 4 tubes.
As for the rectifier 5v 3a tap can I use a ez81? I have actually order.a.hytron 6004 and its in the way. Not much info though for the 6004 but its similar to a 5y3 im I right?
I have a pair of 7k klangfilm just nice for the el3n
Yes I have 4pcs of them through a friends.
Hope to have more.infomation before I start doing it....
Old 8th April 2013, 05:45 PM   #19
Help on transformers pleaseHide this!Advertise here!
Making CT transformers from two transformers infernal Parts 1 14th July 2011 09:42 AM
Where do you get your transformers? OliG Power Supplies 13 28th February 2010 01:53 AM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 11:44 AM
Back to Back transformers as Isolation transformers mikee55 Chip Amps 2 17th March 2006 12:38 PM
Transformers shyfx Solid State 1 29th November 2003 02:10 PM
