diyAudio Sponsor
Old 28th December 2011, 05:17 PM   #1
Default Need to Upgrade Tube Preamp Volume Pot
What would be a good volume pot upgrade for the Matisse design MDS-623 tube preamp? I would like to upgrade because there is some noise and balance issues with the present volume control.
Matisse design Tube-preamp & fumusic MDS-623 &6N3 & AMP | eBay
Old 28th December 2011, 05:56 PM   #2
Stepped attenuators, either DIY or off the shelf, are popular. However, stepped attenuators are expensive and the metal film resistors used in their construction can be "cold" sounding.
PEC of Canada makes hot molded carbon controls that are milspec tough, very good sounding, and not especially costly, You can buy PEC controls from DigiKey. A member of the KKA series is appropriate in the stereo volume control role.
Eli D.
Old 28th December 2011, 07:26 PM   #3
Jebem is offline Jebem  Portugal
Jebem's Avatar
Yap, stepped attenuators are the best choice if money is no object.
But for the price and design of this preamp, I would use one ALPS Blue Velvet potentiometer, as it is adequate and is much cheaper than (good) stepped attenuators.
Old 28th December 2011, 07:37 PM   #4
Rebel Samurai!
AdamThorne's Avatar
Ebay has smd based stepped attenuators ~ $10. Chinese manufacture, I think. Log, stereo, 10K / 50k / 100k ohm. Are they any good? I have no idea.
Old 28th December 2011, 10:29 PM   #5
dgta is offline dgta  United States
From the eBay ad for that preamp:
"the kind of taste the feeling of gallbladder bile reflected most vividly, especially the night also highlighted its charming style."
I gotta get me some
Old 29th December 2011, 01:52 AM   #6
Cheap and good: Analog Metric Limited - DIY Audio Kit
Check out their Dale resistor based stepped attenuator. These sound really good and pay the few bucks more they're asking to have the unit built for you. You'd have to be a brilliant solderer to build it better than they do. I have purchased from them and have had no issues.
Old 29th December 2011, 03:01 AM   #7
Oh go for it! TKD all the way! Regards
Evil looms. Cowboy up. Kill it. Get Paid.
pot in tube preamp chopchip Tubes / Valves 2 5th June 2010 07:57 AM
Looking Schematic converting Volume pot to Digital Vol for tube amp. calico88 Tubes / Valves 6 9th December 2009 06:52 PM
volume pot quite close to a tube - is this okay? jarthel Tubes / Valves 1 19th April 2007 01:20 AM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Effect of using 50k pot instead of 100k pot in tube preamp? KT Tubes / Valves 5 17th February 2006 09:56 PM
Page generated in 0.08929 seconds (74.15% PHP - 25.85% MySQL) with 10 queries
