diyAudio Sponsor
Old 24th December 2011, 08:04 PM   #1
athode is offline athode  Canada
Default replace EL34 with EL37 !?
Hi! I want to know if I can replace the EL34 output tube on my eico HF-89 with EL37 tube and if I need to do some modification on resistor value on the circuit.
Old 24th December 2011, 08:40 PM   #2
why would you EL37 are pretty rare classics . simmilair to 6l6
el34 can be had much easier
Old 24th December 2011, 08:54 PM   #3
It's because I have 4 mullard EL37 and I want to hear it!
Old 24th December 2011, 09:24 PM   #4
kevinkr's Avatar
You may need to reduce the plate voltage significantly, and the grid bias voltage probably needs to be increased into 6L6 territory, -40V or more.
The Mullard EL37 is reputed to be an excellent performer, and I can understand your curiosity, just make sure that you are operating them inside of acceptable plate dissipation, voltage and current values. Since they are yours obviously you can do anything you want with them, and were I you I would try them and if I liked the results would use them. Museum pieces are fine, but...
www.kta-hifi.net
Old 24th December 2011, 09:33 PM   #5
vinylkid58's Avatar
Luckeeeee!
jeff
Old 24th December 2011, 09:50 PM   #6
With the original configuration of the eico HF-89 (EL34) plate voltage is 487v and bias voltage is -46v
Old 25th December 2011, 03:58 AM   #7
ok, swap the 15k and 10 resistor in bias
change B+ supply to full wave bridge type
Bias at approx -15V @ 275 V B+
-13.5@ 250 VB+
depends where the B+ lies when you change the power.
Last edited by DavesNotHere; 25th December 2011 at 04:06 AM. Reason: bias correction
Old 25th December 2011, 10:22 AM   #8
SY's Avatar
I did the swap in an HF87 (which had previously been modified for fixed bias). The EL37s performed spectacularly well. 45 watts at midband.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 25th December 2011, 10:42 AM   #9
h00hbt's Avatar
-13.5@ 250 VB+
Just curious, what would the primary of the OPT be?
Cheers
/H
Old 25th December 2011, 02:42 PM   #10
Does EL34 really same as 6L6 in plate supply and the grids cause, i am still thinking to change El34 into 6L6> In case i had read the data sheet from the wed and i saw the class a voltage supply is really the same but the output power is little bit different> Could any one taught me < Thanks A Lot~
FS: Matched Quad E.H. EL37 Tubes Bengali Swap Meet 2 16th March 2010 10:21 PM
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 05:44 PM
Replace el34 with 6p3s ampere Tubes / Valves 1 28th March 2006 12:50 PM
EL37 ebay auction draget Swap Meet 0 9th August 2005 12:42 PM
what do I replace...? 9am53 Tubes / Valves 10 5th May 2005 02:20 AM
Page generated in 0.07756 seconds (79.66% PHP - 20.34% MySQL) with 11 queries
