Old 13th November 2012, 02:21 PM   #61
tubelab.com's Avatar
Looking 12HL7 tubes, I found the brand Zenith, have any relation with Sylvania?
Zenith did not make their own tubes. They could be made by any of the major manufacturers. It is not uncommon to find several different manufacturers for the same type number. Most of the Zenith branded tubes that I have seen were made by GE.
Someone could point me a part of Mouser or Digikey,
I am at work now ant my populated board is at home, but I used the same long strip of .025 inch square, .100 spacing, pin headder for all the jumpers. Some are cut for 2 pins, some are 3 pins, while JP2 and JP7 are cut for 4 pins. The jumper plugs from an old computer board are used on all of the JP's.
I am considering a build using $1 13GB5's as output tubes
So am I. I got 10 of these, and I am planning to see just what their limits are. Once I get the voltage and load requirements for a reasonably conservative build (1/2 to 3/4 of the melting point) is I will just use an Antek toroid with the two heater windings in series. I am thinking that a higher B+ like 450 volts or so and a 3300 ohm load will be my starting point. I choose that load because I have a large quantity of suitable OPT's. Sweep tubes can eat lots of plate voltage, it's the screen that you must respect.
I have been using these industrial control transformers for some time, but I have never seen one like that. Most have two identical windings on each side that can be seriesed, paralleled, or used individually.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 13th November 2012, 11:44 PM   #62
pso is offline pso  Spain
Hi wicked1, I still have no the boards, I'm waiting to have more information but seems not to have much interest.
For now I'm gather the parts, I have all the tubes 6J4WA, OA2WA, 12HL7, 5AR4, and the cheap 6P3S-e to start, if nothing blows up, buy something from KT88.
One more question, I was looking at the site EDCOR, was thinking about the CXPP50-8-5K for the OPT but I have doubt about the PT, the XPWR002 would work? a center tap is necessary in the heater winding? it that will not work, one could tell me that would be appropriate? I would like a B+ about 420-440V, transformers are expensive and I prefer ask before wrong.
Tubelab.com, thanks for the reply, I wanted to know the brand Zenith was reliable and I see if it is.
Old 13th November 2012, 11:49 PM   #63
If you have the tubes, post a picture showing the type number and maybe we can figure out who made them. GE tubes will usually have the number etched into the glass with some dots etched below the number. Sylvanias usually have the letters USA right below the number. RCA's have the number enclosed in an octagon.
Old 14th November 2012, 12:16 AM   #64
Buy a dozen of 12HL7 , all brand Sylvania, do not buy any Zenith because they do not know the brand, but were identical to Sylvania, now I know they are legit and I can buy, thanks.
Old 14th November 2012, 12:38 AM   #65
I forgot to mention, in relation to the question of the PT, I'm thinking of building monoblocks.
Advantages and disadvantajes?
Old 19th November 2012, 11:10 PM   #66
Something has been missing from my life.......I have been busy with life's little things like going to work to pay the bills....and even some fun things like going to Seattle to see my grandkids.....but there has been no glow, no smoke, damn, the soldering iron hasn't been turned on in....I don't even remember.
Somehow I managed to get this week off of work. We still have "stuff" scattered all over the house since cleaning out the warehouse. The plan was to spend the week sorting and organizing some of the "stuff" and listing some of it on Ebay, but my ADHD took control of my brain and then it happened......
I just needed to see some glow....even if I just connected some junk tubes up to a power supply and fried the life out of them.....it had to be done. Before I could connect the clip leads up to the power supply.....zap ADHD had planted another thought.
Last February I built two of these boards. I lit one of them up and extracted about 10 watts out of it WITHOUT any output tubes. That was post #36.....the board has been sitting on a shelf ever since. Well, I have a working driver board, a bunch of power supplies, some turret boards for several flavors of tubes, and lots of tubes, so maybe it's time to turn on that soldering iron......
Damn, it doesn't work. That's right, Tubelab doesn't even have a working soldering iron, NOOOOOOOO. I know there is another one here somewhere.....but where. I spent about an hour looking for it last night, then another hour this morning, so time for a brain shock......I jump in the cold swimming pool!!!!! 5 minutes later I am opening a box that contains a brand new soldering iron I bought a couple of years ago because the tip was stuck in my 15 year old iron.
OK, I have an iron, boards, power supplies, tubes, and all the other stuff I need.....Now, which tubes do I FRY.....no I mean "test". I have a credit at two tube stores since I have been selling off my tube collection, so how about one that is on the dollar menu......Then I remembered this:
I am considering a build using $1 13GB5's as output tubes and a 1200 ohm plate to plate impedance output transformer
Well, I got 10 of them, they are on the dollar menu, so easy choice.....hook em up.....light em up.....Damn these little tubes CRANK!......Like how much power does it take to make these things GLOW.......50 watts......no too easy.....do I hear 100......NO GLOW YET.....CRANKKKKK.... a pair of these little guys can crank out 150 WATTS and just begin to show glow. Thats 150 W RMS at 3% distortion! Full cranked square waves read 190 Watts on the HP8903, but that's not really accurate.
I stopped twisting the dial at 600 volts because the last time I dimed the power supply into one of Pete's red boards there was a rather BIG BANG and a capacitor vanished. I don't remember exactly what voltage caps are in this board.....
So the details.....Load impedance is 3300 ohms. I am running a 6600 ohm OPT with a big fat 8.02 ohm Dale 120 watt resistor across the 16 ohm tap. Same setup I use with the big sweep tubes in Pete's big red board. The bias was adjusted for 35 mA per tube, and the screen voltage was set to 175 volts. I tested the setup at plate voltages from 300 volts to 600 volts. The same B+ supply was fed to the driver board and the output tubes. A second supply runs the output screens at 175 volts, and a third provides -80 volts to the red board.
I set the B+, set the bias to 35mA and cranked the signal generator until the audio analyzer read 3% THD, and pressed the power output button.
300 Volts 30 Watts
350 Volts 56 Watts
400 Volts 72 Watts
450 Volts 91 Watts
500 Volts 106 Watts
550 Volts 125 Watts
600 Volts 152 Watts
Don't know how they will work at 1200 ohms, but I suspect that's too low. I was surprised to see thay they liked 3300, most tubes this size don't like much below 5000. I have a way to do 2500 and 1250 ohms, but it involves finding an OPT that I haven't seen in at least a year.
I have some BIGGER tubes to test that might like the lower load, so I'll look for it.
Old 19th November 2012, 11:45 PM   #67
Wow!!!, impressive resistance.
Old 20th November 2012, 12:45 AM   #68
Tony is offline Tony  Philippines
Tony's Avatar
way to go George.......that's was awesome as always......the 13GB5 looks a lot like the PL504 although filament is 27 volts....expect those tubes to disappear soon...
Old 20th November 2012, 01:21 AM   #69
There is a 27 volt version, the 27GB5. I have two, but they are Japanese, and very well used.....abused. The 27GB5 is a PL500 which is listed as a substitute for a PL504. Maybe a similar tube.
Kinda hard for a pair of 400 watt OPT's to hide. They have been found, hookup tomorrow......maybe.
Old 20th November 2012, 03:03 AM   #70
Cassiel is offline Cassiel  Libya
Cassiel's Avatar
Like how much power does it take to make these things GLOW.......50 watts......no too easy.....do I hear 100......NO GLOW YET.....CRANKKKKK.....
Hilarious stuff, keep it up.
Hello
idiot proof mono push pull 6l6gc schematic wanted jasondace2b Tubes / Valves 29 13th October 2011 01:22 AM
Mono 5W-17W Power Amp using EL84 push-pull nbraz Tubes / Valves 30 27th July 2011 11:12 PM
Please Explain difference Mono vs Push Pull vs Single End etc hdlcx2 Tubes / Valves 11 3rd August 2008 02:27 AM
Push-Pull driver stage? alexmoose Tubes / Valves 12 18th September 2006 11:38 PM
Copyright ©1999-2013 diyAudio
