Mono push-pull driver PCB
Old 3rd March 2013, 06:35 PM   #211
wicked1 is offline wicked1  United States
wicked1's Avatar
I got a new multimeter, and my voltages are all different now.. High voltages are lower, and low voltages are higher!
Only one I'm really concerned w/ is the heater. My new meter is saying it's 7.5v.
Should I drop that w/ a resistor? (I'd probably do 2, one on each leg to share the power dissipation)
Or, are there better ways, or would you not worry about it?
Pete, if you see this and have a minute... If you're using the 100v taps, could you measure your heater? My mains are 119.5ish volts and heater is 7.5v w/ my new meter. 2 old meters show a different reading (6.9v), but this new one is supposed to be calibrated.
Old 3rd March 2013, 10:05 PM   #212
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
my meters tend to display higher reading when the batteries are about to drain out, you can check that the 9 volt battery is 9 volts, anything less, replace the battery with fresh ones...
i have a bout 5 dmm's 2 of which are Fluke 87's, i use the Flukes as reference for the other less expensive dmm's...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th March 2013, 08:25 PM   #213
wicked1's Avatar
New meter is a fluke.. New battery.
It's True RMS, and the old cheap meters are not. That shouldn't make a difference for measuring the heater voltage, should it?
As I said the new meter SHOULD be calibrated, and better at reading low AC voltages, but I've tested it w/ three 'cheap' meters, and they all say 6.9v, while the new calibrated fluke is the only one that says 7.5v.
Old 4th March 2013, 09:49 PM   #214
TonyTecson's Avatar
7.5v is high, is that all the time or only during certein times of the day? a resistor is called for here....
Old 4th March 2013, 11:06 PM   #215
wicked1's Avatar
Yes all the time. I guess I will trust the new meter. (Maybe my AC is very distorted, so the averaging meters aren't getting a good measurement. I need a new scope)
I've got so much voltage to burn, I could convert it to DC. But, the amplifier is quiet.. No need to add complexity.
Old 5th March 2013, 12:05 AM   #216
davefl is offline davefl  United States
Pete, being all too generous, loaned me his new amps for a while so I've taken some measurements for you. He's using the 120 V tap (brown wire on the classic tone) and my line is at 121.6 v right now. Heaters are at 6.5 v. I calculate that on the 100 v tap this would give 7.8 on the heaters. Sounds like you're right on with the 7.5 you're measuring.
Old 5th March 2013, 01:06 AM   #217
Since Pete was generous enough to loan me his new amps, I thought the least I could do was leave some comments on how they sound. So I'll offer what meaningful info I can. I'll preface by saying that even though we built the enclosures for the amps, I'm not trying to play them up just to sell more boxes - take it for what you will.
If you're anything like me, you have a hard time deciding what to spend your time and money on with all the interesting projects out there. Having listened to Pete's amps for a while now, I will definitely be building myself a set. If you can duplicate Pete's effort, you'll have a great set of amps too!!
So far, I, and others, have listened to the amps with a set of large DIY 3-way horns (about 100 dB efficient), a set of Madisound full-range folded horns (BK-12m), a set of Vandersteen Model 3's and my old faithful Klipsch Heresy II's.
The large 3-way horns aren't anything to rave about, but they did reveal how quiet the amps are. With my head right next to the speaker, I can't hear any hum - none. There's a turn-on buzz for a second or so, but not very loud, and a distinct thump when you power down. Neither one is loud enough to make me think there's any risk of harm.
The little folded horns were a fun project, but mostly sit in the corner. I hooked them up and just had to listen for a while. I was impressed. They're light in the bass, as you might expect, but otherwise quite impressive. If I had these amps when I built them, they might not have wandered off to collect dust. No flowery words to describe the sound, they play music and it sounds like music (sorry, I'm not an audio reviewer).
The Vandersteen 3's: now this is an impressive combination. I can honestly say that I've never before had speakers as revealing or amps as good as these in my house. Everything is crystal clear. The sound is clean, fast, dynamic, etc. Vandersteen recommends 100 - 200 wpc, but these amps work! The owner of these speakers says they sounded a little fuller with his 200 wpc Counterpoint amp - but they self destructed years ago. I've listened to more records and cd's in the last couple of weeks than I usually do in months. Great recordings sound great, bad recordings sound bad. I never quite realized how much of a difference there could be between the two.
My old faithful Heresy's: I've listened to every amp I've had in my possession over the last 18 years through these speakers and have never heard them sound this good. I can put on a good record at a decent volume (yea, kinda loud) and instruments just jump out at you - I still laugh at the effect sometimes. I've never owned any high-end boutique amps, but have had numerous classic SS and tube amps, some home-made SE 2A3's, and random other amps that friends have sent my way. So again, nothing exotic to compare to, but quite a few amps nonetheless.
Hopefully you find my comments useful. These are my opinions and the opinions of others that have listened to Pete's amps.
Old 5th March 2013, 01:18 AM   #218
TonyTecson's Avatar
a resistor or a thermistor, you know the types found on atx psu's, i use them to lose volts of 1volt or less...
Old 5th March 2013, 02:05 PM   #219
wicked1's Avatar
thank you both! Dave for the confirmation of my voltage reading, and the review. I agree w/ all of it. I have been very impressed w/ this amp. I use different output tubes, and regulated some voltages, but I'd bet they sound the same. Pete's driver section is very well designed. Actually, for a bit of a review comment, I was listening to the amps w/ some friends, and we kept turning it up louder and louder, and finally realized we couldn't hear each other talking. It didn't seem loud in the traditional sense, because there was no distortion.. I'm used to concerts and clubs where loud = distorted, so am sort of preconditioned to thinking distortion=loud.
Tony, that's a great idea! I've been getting a lot of good parts out of old computer PSU's, but have never tried the thermistor. I'll get down to my scrap pile later and find one.
Otherwise, looks like I need a couple of .06 ohm 5w resistors.
Old 5th March 2013, 10:17 PM   #220
TonyTecson's Avatar
i often rescue crt monitors and atx psu's from the dumpsters, lot's of yummy parts to be had....
Mono push-pull driver PCBHide this!Advertise here!
idiot proof mono push pull 6l6gc schematic wanted jasondace2b Tubes / Valves 29 13th October 2011 01:22 AM
Mono 5W-17W Power Amp using EL84 push-pull nbraz Tubes / Valves 30 27th July 2011 11:12 PM
Please Explain difference Mono vs Push Pull vs Single End etc hdlcx2 Tubes / Valves 11 3rd August 2008 02:27 AM
Push-Pull driver stage? alexmoose Tubes / Valves 12 18th September 2006 11:38 PM
