Mono push-pull driver PCB
Old 26th December 2011, 08:05 PM   #11
pmillett is offline pmillett  United States
pmillett's Avatar
Originally Posted by bayermar View Post
Hi Pete,
do you think it would be possible to apply plate-to-plate (aka Schade) feedback with this driver board?
Yes, though I implemented it a little differently - I have positions for resistors from each driver plate to both B+ and to an off-board connection, which could be to the output plate, or to the unltralinear taps. So you can dial in the amount of feedback by adjusting the ratio of the two resistors.
You can also leave out the input tube and build this as a 2-stage amp. Maybe I will add some provisions to apply gNFB to the other side of the diff amp, as is done in the Baby Huey amp you reference...
Pete
Old 26th December 2011, 08:07 PM   #12
pmillett's Avatar
Originally Posted by pso View Post
This little PCB are already for sale ?
Nope, not yet... it will be a few weeks.
Pete
Old 27th December 2011, 10:12 AM   #13
bayermar is offline bayermar  Germany
bayermar's Avatar
Pete
That sounds really nice!!!
So, when you say universal, you really DO mean universal.
Sounds like a lot of thoughts went into this board.
I appreciate that.
Thanks!
Martin
Old 27th December 2011, 04:52 PM   #14
pmillett's Avatar
OK, I made a few more tweaks, and wrote up a full circuit description on the web site. Please have a look, let me know of any errors you see, or any other requests...
Push-pull driver board
Thanks,
Pete
Old 18th January 2012, 06:18 PM   #15
kegger is offline kegger  United States
R.I.P.
I've looked over the latest Pete,
(quite nice additions there)
You've certainly gotten my interest.
(should make a great test platform)
Old 19th January 2012, 01:45 AM   #16
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
"or any other requests..."
Would be nice to have some resistor positions, with cathode fdbk nodes, in the two cathodes of the 12GN7 drivers. (Like in the RCA tube handbook for their 50 Watt amplifier). But that likely won't work out with the current self splitting of the driver stage. Could maybe leave room for a small (optional) HV Mosfet Concertina splitter stage in front of the drivers to operate the two driver grids then.
Old 19th January 2012, 12:34 PM   #17
pmillett's Avatar
Ah, a little too late... PCBs are on their way to me now...
I'm in Asia at the moment, but will post more info when I get home this weekend.
Pete
Old 20th January 2012, 03:00 AM   #18
roline is offline roline  United States
roline's Avatar
Watch out for the frog in hot chili oil, The frog is OK a little crunchy, its the chili oil that gets you the next day.... I had a stint in Langfang last yr, quite an experience, no time to chase audio parts.
I like the PCB, 6L6 or 6LB6 family should work great with it. Bias for the screens of the 6LB6's?? It could be done off board zener stack on power supply. Lots of feedback and bias options...I especially like the CCS on the second stage and Schade feedback from the output tubes. I appreciate that your work will open up the realm of tube amps to nubies eager to try their hand at it. I wish that this was available a couple yrs ago when I decided to try the enlightened path of tube amps, it is a great step up to what was available then, looks like a great breadboard to learn from. A far nicer PCB than the toner transfers that I've been making..
SO many tubes, SO little time!!!
Old 3rd February 2012, 08:19 PM   #19
wicked1 is offline wicked1  United States
wicked1's Avatar
How's the progress on these PCB's?
Old 3rd February 2012, 08:25 PM   #20
pmillett's Avatar
I have the new rev boards (red, or course) in house now... I've been traveling again (just got back) so I have not found time to document it on the web site.
I will try and get at least some info and pictures on the website and get them on eBay this weekend... it might take a little longer for me to actually build up a pair for myself.
Pete
Mono push-pull driver PCBHide this!Advertise here!
idiot proof mono push pull 6l6gc schematic wanted jasondace2b Tubes / Valves 29 13th October 2011 01:22 AM
Mono 5W-17W Power Amp using EL84 push-pull nbraz Tubes / Valves 30 27th July 2011 11:12 PM
Please Explain difference Mono vs Push Pull vs Single End etc hdlcx2 Tubes / Valves 11 3rd August 2008 02:27 AM
Push-Pull driver stage? alexmoose Tubes / Valves 12 18th September 2006 11:38 PM
