Mono push-pull driver PCB
Old 21st November 2012, 05:50 PM   #91
pmillett is offline pmillett  United States
pmillett's Avatar
Wow... I've been out of touch on vacation for a week, and much has happened! Glad to see George is going down the sweep tube path!
I think I've decided to work up a build using PPP 807's (or 1625, 5933, or 829B... maybe 6146?) to do ~100W. I'm thinking B+ of 600V, G2 of 225-300V, 5k load impedance. I'm hoping to configure the driver so it can run down to 200V to allow the G2 supply to run the driver (829B is rated 225V max, 807 300V). Should only need around +/-35V of grid drive so hopefully it will work that low.
That will be step one. Then the rest... power supplies, etc. I think I'll ditch using any of my existing iron and spend the $$ for new Edcor transformers, and have them do a custom power xfmr. Contribute to the economy
Pete
Old 21st November 2012, 08:56 PM   #92
wicked1 is online now wicked1  United States
wicked1's Avatar
This is exciting! Time to dust off the workbench. I hope I can contribute something. If nothing else, I'm great at designing the chassis(subjective, I know), and will certainly share my cad drawing when we get to that point.
I don't have any power iron, so will definitely join in getting what you have made.
Old 22nd November 2012, 12:30 AM   #93
pso is offline pso  Spain
HI Pete, look set to go with 100W or more, means that you leave the prototype triode-KT88? there has ben some progress? was happy with the sound?.
I have the tubes and I'm waiting a budget of EDCOR for the custom transformer.
750V (375-0-375) at 400mA, center tapped.
70V at 150mA.
6,3V at 10A.
5V at 3A.
As you see it? if you are thinking about ordering some custom transformer valid for the trioded-KT88, I'll wait.
I was waiting for to get some more information, and maybe, a list of parts.
I'm not an experienced builder, but I think I could do it.
Old 22nd November 2012, 01:50 AM   #94
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Pete mentioned transmitting tubes, so why not. It's just a test so why not go BIG. Well I have some 833A's, but I don't have the bench space nor a few KV, nor an OPT big enough to eat it......so think a little smaller.....Why not a pair of 813's. I know I could squeeze more juice out of some bigger sweep tubes, but a pair of brightly glowing DHP's would look COOL.
OK, I got tubes, sockets, and plate caps, so.....hook em up...light em up.....and....
I have 4 tubes and ALL of them are DEAD.....
One of them is so dead that I can measure 0 ohms between G2 and G3.
Well at least they look cool.
NEXT......something smaller.....way smaller
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 22nd November 2012, 03:34 AM   #95
Cassiel is offline Cassiel  Libya
Yes they do. Bummer.
Oh my God the size of that resistor!
Old 22nd November 2012, 07:13 AM   #96
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
hey George, you probably know i am into 4D32 pp amp, any future plans to torture these tubes.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 22nd November 2012, 03:24 PM   #97
Still impressed with the memory of that resistor I went to look for mine....it's a two watter! Yes, I troubleshoot my amps with a two watter as a load. Serious lack of power here.
Old 23rd November 2012, 02:40 AM   #98
That's one of my little load resistors...its only rated for 120 watts, which I have already exceeded this week. Really big amps need a really big resistor. This one is rated for 500 watts, and I have fed it 525 watts using one of Petes big red boards and 35LR6's with both channels paralleled.
Yes, there is. The specs state that for maximum fun AB2 is needed. This little board won't really go there until I make a mosfer buffer board. Then you will see some AB2 testing on the 4D32 and some more mundane tubes like the 6L6GC. The mosfet buffer board will allow for some screen drive experiments on some sweep tubes like the little 13GB5 too.
Old 23rd November 2012, 03:04 AM   #99
TonyTecson's Avatar
thanks George, looking forward to it...
Old 23rd November 2012, 02:04 PM   #100
Wow George, you're playing in major league INDEED. I'm just a small-time player.
Mono push-pull driver PCBHide this!Advertise here!
idiot proof mono push pull 6l6gc schematic wanted jasondace2b Tubes / Valves 29 13th October 2011 02:22 AM
Mono 5W-17W Power Amp using EL84 push-pull nbraz Tubes / Valves 30 28th July 2011 12:12 AM
Please Explain difference Mono vs Push Pull vs Single End etc hdlcx2 Tubes / Valves 11 3rd August 2008 03:27 AM
Push-Pull driver stage? alexmoose Tubes / Valves 12 19th September 2006 12:38 AM
Copyright ©1999-2017 diyAudio
