diyAudio Sponsor
Old 15th September 2003, 07:10 PM   #1
drembo is offline drembo  United States
Default isolating mounts for transformers
The builder of the amp at this site: http://indigo.ie/~walton/300b.html
used rubber mounts to isolate the transformers and choke from the chassis. What is the purpose of this? Is it safe not to have the case of the power transformer connected to ground? What about any shielding provided by the case?
Old 15th September 2003, 07:20 PM   #2
Sjef is offline Sjef  Netherlands
This isolation works as a mechanical isolator. It prevents the whole chassis from humming together with your transformers. Good thing to do and relatively simple.
I have tried earthing of transformers and chokes but I really can't hear any difference.
Old 15th September 2003, 10:42 PM   #3
diyAudio Senior Member
fdegrove's Avatar
No problem.
I'd recommend rubber washers or similar to control xformer / choke induced vibes from entering the main chassis.
When not tightened too hard simple rubber grommets can be quite effective.
Frank
DIY speaker wall mounts for b3s chubby chaser Full Range 20 12th April 2008 11:03 PM
small display mounts Phatriff Parts 2 13th October 2007 10:54 AM
3 pin XLR connectors & chassis mounts rlim Swap Meet 1 18th February 2003 03:10 AM
S-video chassis mounts? Arbury Everything Else 4 14th January 2002 09:08 PM
Page generated in 0.09888 seconds (52.55% PHP - 47.45% MySQL) with 10 queries
