| diyAudio Sponsor | ||
Hi All, I recently got a bee in my bonnet to build an amp after I found a '59 Lowrey organ chassis (complete) on ebay (haven't played with tubes in many years). Long story short, I have it built, based on a mix of a 5F6A (output) and Marshall Bluesbreaker (preamp) designs.
Problem is that the power transformer gets a lot hotter than I would have expected. Rectification is SS fullwave, yielding a +B of about 520V. To keep the temp buildup in the PTX so it can still be touched I run it with very cold biasing (10mA), for a total HT load of under 30mA at low-medium listening levels. By my calculations the HT winding should be able to deliver 80mA without blistering the paint. I am using a pair of used Magnavox 7027A tubes (like them more than the cheap 6L6GCs I picked up) PTX measured/calculated specs: 120V PRI (original fusing was 2A Slow Blow, estimated 175VA) HT - 475-0-475VAC (also fused at 2A SB) Fil 1 - 6.5CT Fil 2 - 6.5 Original Tube Complement: 2 x 6AU4 2 x 6L6GC 2 x 6SN7GT 1 x 6SL7GT 2 x 6X8 5 x 12AX7 on a separate chassis Calculated loads: HT - about 150mA minimum Fil - 9.3A Other Transformers on the chassis: Filament (about a 175VA core, implying about 27A, most probably for the other 57 6X8s @ .45A each) Output - Approx 40W So, my question is: What could be the reason for the unexpected thermal reaction of the PTX, and what could one do about it (short of rewinding it)? |
| Massive amp modification - basic questions - Rotel RB991 donor | inteificio | Solid State | 19 | 1st December 2010 08:13 AM |
| Donor stereo 845 amp- now what!? | blackeye*_0 | Tubes / Valves | 19 | 3rd December 2009 08:09 PM |
| Donor H/K A224 Amp | VeeDub | Tubes / Valves | 3 | 1st May 2007 08:47 AM |
| Lowrey MX1 organ | tuathal | Instruments and Amps | 8 | 21st December 2006 04:31 PM |
| Page generated in 0.06359 seconds (70.32% PHP - 29.68% MySQL) with 10 queries |
