Help with deciding to build or buy Tube amp.
Old 23rd December 2011, 04:21 AM   #21
ke4mcl is offline ke4mcl  United States
eli,
in that schem what does the symbol with two overlapping circles at the end of one of the resistors between the 12at7's mean?
certified packrat
Old 23rd December 2011, 09:31 AM   #22
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Originally Posted by ke4mcl View Post
eli,
Constant Current Source, as drawn on page 2.
Old 23rd December 2011, 04:45 PM   #23
ChrisA is offline ChrisA  United States
Originally Posted by bigaudioscotto View Post
.. I like big warm punchy bass
and thick syrupy mids and large soundstage ..
Maybe what you need are speakers. A good amp sounds like "a wire with gain".
If you are looking to create a sound you should be looking at musical instruments amps and PA systems. Those are what make music. Stereos reproduce sound. That is completely 100% different from producing sound.
The first questions to ask yourself is "How big is the room? How far am I from the speakers? What volume level do I want? (Best if you can saying terms of dB) Then you need to know the sensitivity of the speakers you will be using.
OK now you know your minimum power in watts. You may not like that answer and then you change something above (most likely the speakers) Finally you have the minimum watts. It is reasonable to use a mutiplier on that minimum in order to have some headroom.
For most people they settle on about 8 to 12 watts per side and speakers to rate "high 90s"
If you have some old speakers from the mid 70s with senitivy in the low 80dB range this tube amp is going to be quite expensive. You'd be best to replace the speakers as 50W per channel tube amps are NOT a first time project and are actually quite rare.
Old 16th June 2012, 07:22 PM   #24
disco is offline disco  Netherlands
disco's Avatar
On the other hand... a tone control can be a benefit to compensate for boominess in a room. As is the placement of the loudspeaker of course, while not everyone is in multichannel.
jaap
Old 16th June 2012, 08:14 PM   #25
costis_n is offline costis_n  Greece
Originally Posted by Eli Duttman View Post
Lot's of good options have been presented. Naturally, I'll grind my own axe.
Build an "El Cheapo" with triode/ultralinear (UL) mode switches. The reasonably efficient open baffle speakers will produce "bleeding ear" volumes for heavy metal, etc., in UL mode. Triode mode offers greater finesse, for jazz and classical.
The attached schematic (triode mode) shows 12AQ5s, but any 6V6 family tube will work, without parts value changes. Please notice that a line stage is unnecessary. Use good O/P "iron", like Dynaclone Z565s, and full bass extension is available. Simply change the bandwith limiting combo at the I/P from 56 nF./100 KOhms to 68 nF./127 KOhms (RN65).
Jim McShane is the man for tubes and parts. Well under $100 buys a full set of power magnetics (will list if interested) from Allied.
I noticed that the first stage smoothing capacitors are 820+820 uf (410uf in effect). Why are they so big, it makes no difference at all in this position.
Help with deciding to build or buy Tube amp.Hide this!Advertise here!
Looking to build some big 3 way's Need some help deciding on the woofer. Boscoe Multi-Way 11 5th October 2010 09:20 AM
Help deciding on my first amp build please. m0cea Solid State 4 22nd August 2010 11:19 PM
Need help deciding what to build keckepro Tubes / Valves 0 26th September 2008 02:13 PM
Deciding on design / kit for first build pyromaneyakk Multi-Way 0 2nd August 2008 09:05 AM
Help on deciding what to build - problem room. Emprov Multi-Way 2 25th August 2005 04:50 PM
