diyAudio Sponsor
Old 22nd December 2011, 01:29 PM   #1
male42 is offline male42  Russian Federation
male42's Avatar
Default placing the volume control
I want to set the volume control after the tube driver. in the case of transformer coupling between stages, we can draw conclusions for walking step. think that in this case will be less noise. your thoughts.? My English is bad translator.
__________________http://www.mostsound.narod.ru
Old 22nd December 2011, 04:28 PM   #2
Miles Prower's Avatar
Not necessary unless you have a low level input signal. For the usual 1.0Vrms source, just put the volume control up front.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 22nd December 2011, 04:30 PM   #3
Alastair E's Avatar
After the tube driver....
Not a good place, the drive impedance seen by O/P tubes will alter depending on pot position which can/will affect sound....
Vol-pots are placed at the input to power-amps for a reason!
Das Beste Oder Nichts
Old 22nd December 2011, 09:49 PM   #4
ChrisA is offline ChrisA  United States
What you say is common in guitar amps but not in audio. The guitar needs a constant 1M input impedance from the amp so a volume control before the gain stage can't work. But then that solution only kicks the variable impedance problem down to the next stage.
The "best" solution for audio is simply to not have a volume control on a power amp. All your sources likely already have a volume control, so way another one in the amp?
Old 23rd December 2011, 08:52 AM   #5
"grid bias" style volume knob
Old 23rd December 2011, 11:05 AM   #6
male42's Avatar
in the case of the guitar amp is not clear. if the regulator is equal to 1 M, then for any rotation of contact input impedance will be 1M. or you have not properly understood. I give the image that was meant. I think it makes no difference where the volume control, but gain for noise and fire. and look at the case of the transformer.
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Remote control Passive Volume Control with Display ua100k Swap Meet 2 31st May 2011 03:01 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Page generated in 0.10068 seconds (79.80% PHP - 20.20% MySQL) with 11 queries
