| diyAudio Sponsor | ||
Anybody here knows this tube, or better yet, has used it in audio?
datasheet: http://www.mif.pg.gda.pl/homepages/f...020/6/6FN5.pdf (in french)
Real tubes have top-caps |
#2 |
as for all TV sweep tubes I suspect poor performance when considering single-ended class A mode. However, push-pull should work. |
#3 |
Some make amazing triodes . . .
#4 |
Exactly what i'd like to find out..
#5 |
Unfortunatly I've no curves available for this tube.
Just look at one of its cousins: EL/PL36 Not worst than a 2A3, no need for DC heater and a bit easier to drive ![]() Yves. |
#6 |
Yes, I am familiar with the PL36
Is it possible to create the triode curves from the pentode curves? Or is the only accurate method to measure them?
#7 |
The data sheet does not tell anything above 200 Vanode and only for 3 screen values, I fear that extrapolation be very approximate !
If you aren't lazy, 2 adjustable power supplies and 3 DVM is just what you need to measure . . . along with pen and paper . . . or a calc sheet
#8 |
Ok I measured the characteristics with my scope (with individual grid settings)
Now I need to combine those characteristics into one, I could use excel, but maybe you know a better program for this?
#9 |
Tadaaa!
Left most curve is 0V, from there on i used 5V increments. Dissipation curve drawn is for 22,6 W (17,6+5) but I believe this tube can handle some more... Now how do I calculate mu, rp, ideal plate load etc?
Real tubes have top-caps Last edited by hidnplayr; 22nd December 2011 at 10:57 AM. |
#10 |
Hey, you're going fast ! !
Do you have some numeric series as f.e. Ua, Ia, Vg 50, 80,0 100, 270, 0 150, 480, 0 . . . 50, 10, -10 100, 75, -10 etc ... (values roughly estimated from your picture) ? |
| FS: DIY Tube parts, tubes 845's teflon, tube phono PCBs | tronan | Swap Meet | 4 | 3rd December 2011 01:19 AM |
| Telefunken Tube Receiver, Magnetophon 97 (Tube R2R) and Record Player | Dredfred | Swap Meet | 1 | 3rd April 2011 01:12 AM |
| FS tube tuner, Active filter kit, tube amp, amp3 | Josephjcole | Swap Meet | 9 | 20th July 2007 04:05 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| Page generated in 1.15874 seconds (7.95% PHP - 92.05% MySQL) with 11 queries |
