Expert advice on what preamp to chose
Old 21st December 2011, 07:06 AM   #11
CENTRAL is offline CENTRAL  Greece
CENTRAL's Avatar
Originally Posted by Eli Duttman View Post
What is the signal level needed to drive the power amp to full O/P? If it's less than the 2 V. "standard" digital signal sources produce, you don't need a line stage with gain.
Passive preamp is an oxymoron! However, a passive control center may be satisfactory. A buffered level control, with source switching, rates (IMO) to be the best bet, should line stage gain be unnecessary.
Hi there!
I checked with the power amp's specs and they won't refer to that value...
Old 21st December 2011, 07:24 AM   #12
suntechnik is offline suntechnik  Russian Federation
AtmaSphere very well regarded stuff Atma-Sphere music systems, inc.
I am owning a simpler preamp Italian Graaf 13.5 II and absolutly love it. Conrad Johonson/McIntosh gear is another option to consider.
For DIY you may google EF86 or mu-follower.
Old 21st December 2011, 07:27 AM   #13
CENTRAL's Avatar
Somebody also proposed this one which I like...
Foreplay Line Stage kit
Old 21st December 2011, 08:31 AM   #14
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Again, it has a lot of gain. If I were in the market for a preamp with little to no gain, I'd probably pick up a Firstwatt B1. It will likely embarrass the ones you have linked. And, if you are so inclined, outside of the chassis, you can build one for about $40.
Old 21st December 2011, 08:52 AM   #15
CENTRAL's Avatar
I can only trust your expertise here...
The power amp is this (and he stays forever)
Lyngdorf - Product - SDA 2175
What would you pair it with?
Let me say that it has no character whatsoever. It only amplifies signals - that's it.
Old 21st December 2011, 08:55 AM   #16
costis_n is offline costis_n  Greece
If the power amplifier is so boring, it is understandable you want to connect an effects box in front of it!
Old 21st December 2011, 08:59 AM   #17
CENTRAL's Avatar
You could say boring, it changes nothing.
This power amp is the epitome of amplification. He can push hundreds of watts effortlesly and in a way you beg for more.
It's the one component I would not change.
Old 21st December 2011, 09:02 AM   #18
Anyway, I read the Owner's Manual for you, it says it has 2V sensitivity.
Also, it has balanced (XLR) inputs too. It is better to get a preamplifier with XLR outputs.
Old 21st December 2011, 09:05 AM   #19
CENTRAL's Avatar
I already have. I'm looking for a second one - different taste - or maybe a replacement.
Old 21st December 2011, 09:12 AM   #20
CENTRAL's Avatar
The B1 only offers 2 inputs which is no use...
Any other solution with more inputs maybe?
Expert advice on what preamp to choseHide this!Advertise here!
Requesting expert advice. jasongalambos Car Audio 2 16th August 2011 04:31 AM
Major amp circuit redesign- need some expert advice ambience exists Tubes / Valves 6 13th June 2009 10:16 PM
Newb looking for some expert advice for his first project (5.1 speakers) tim_programmer Multi-Way 3 19th July 2008 06:42 AM
I need some eq. hook up expert advice please! graykeene Tubes / Valves 0 11th July 2007 09:44 PM
Need advice to chose best toroidal transformer for LM3875 monoblock? Norris Wilson Chip Amps 6 25th August 2004 11:58 AM
Copyright ©1999-2017 diyAudio
