diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   input transformer - mumetal casing etc. (http://www.diyaudio.com/forums/tubes-valves/202795-input-transformer-mumetal-casing-etc.html)
Alexontherocks 19th December 2011 02:09 PM
Dear All, investingating the possibility of building a pmillet universal PP amplifier
Push-pull KT88 class A amp with "universal" driver PCB
I researched one of the most expensive components (on the PCB that is)...the input transformer.
either a sowter or lundhal will do according to pete millet. Here is the link to the sowter product
3575
To reduce cost and shipping problems I would have liked to have all the transformer parts made and shipped through edcor electronics. I have contacted them in relation to the sowter part (to have it "cloned") and the reply is the following:
1. They don't use mumetal cans or electrostatic shielding
2. "What we can do is the 1:1 ratio PC and PCW series transformers (on our website) and could put a external copper shield on the transformer for an additional cost"
I am no engineer and would like to ask some input to some of the guys on the forum. Can such a solution work? Waht would be a good choice among the EDCOR products to emulate the charaacteristics of the sowter part?
Alex
Alexontherocks 19th December 2011 02:16 PM
one of the solutions might be this:
EDCOR Electronics Corporation. PCW10K/10K
or
EDCOR Electronics Corporation. WSM10K/10K
comments?
Thanks again
Alex
male42 19th December 2011 02:24 PM
If I understand you correctly, then the input transformer should have a screen. preferably of magnetic material. such as permalloy, nickel-containing alloys. sometimes requires a dual screen. copper in this case is not suitable.
Alexontherocks 19th December 2011 02:26 PM
The sowter seems to have one, I guess the edcor should have one as well...
what would be the effect from using copper instead of a megnetic material?
pieter t 19th December 2011 02:31 PM
[QUOTE=Alexontherocks;2826761
what would be the effect from using copper instead of a megnetic material?[/QUOTE]
No screening from low frequency stray fields.
male42 19th December 2011 02:32 PM
you need to protect the transformer coil from external parasitic interference with magnetic origin. such as power transformer. Copper does not have this property
Alexontherocks 19th December 2011 02:35 PM
Is there anyway to obtain sheets of magnetic material and have them formed to create a screen?
In conclusion you all foresee problems with using the EDCOR alternative, correct?
I have plenty of tools and machines (a friend has a CNC/metalwork shop) so forming, bending and such would not be a problem...
SY 19th December 2011 02:36 PM
Go Cinemag. Prices are very reasonable and the quality is as good/better than Sowter. The input transformer I've been using seems identical in performance to the Jensen JT11P1 at half the price.
Alexontherocks 19th December 2011 02:38 PM
cinemag's site seems to be down...
SY 19th December 2011 02:42 PM
Audio Transformers By Cinemag Inc.
Came right up for me.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
