Old 19th December 2011, 02:45 PM   #11
now it works....must have been my wireless connection.
is there any model which could be considered a direct equivalent of the sowter part?
Old 19th December 2011, 02:46 PM   #12
male42 is offline male42  Russian Federation
male42's Avatar
I have made myself such transformers. and recommend a dual screen .. need to check in practice
__________________http://www.mostsound.narod.ru
Old 20th December 2011, 02:54 PM   #13
Cinemag replide and stated that the CMLI-15/15B would be a good choice to replace the sowter part.
http://www.cinemag.biz/line_input/CMLI-15-15B.pdf
is the dual shielding necessary from a practical point of view?
Old 20th December 2011, 02:57 PM   #14
SY's Avatar
It can't hurt! I've gotten such excellent noise rejection performance from the Cinemags (and Jensens) that I just go with it and try not to question their wisdom.
If there's a sucker born every minute, where do the rest of them come from?
Old 20th December 2011, 05:09 PM   #15
kevinkr's Avatar
Dual shielding is quite important if the transformer is a conventional EI core type which has poor rejection of external magnetic fields. Toroids and C-cores tend to need less shielding as they seem to contain their own magnetic fields more effectively and in so doing are also generally less susceptible to external fields.
I use transformer coupling extensively in my system, and use shielded transformers everywhere except in the driver stage and OPT. The IT is an unshielded Lundahl C-core which given the high signal levels is not a problem. I do go to some trouble to keep power transformers far away from these transformers if possible.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 20th December 2011, 08:16 PM   #16
trobbins's Avatar
This paper from 1938 includes a good level of practical measurements to guide those wanting to diy. I may be wrong, but I think the casing metal sheet used for some old floppy disk drives was made from a better magnetic shielding type of steel - it was certainly quite maleable for bending in to shapes.
http://dalmura.com.au/projects/Magne...uly%201938.pdf
Old 20th December 2011, 08:21 PM   #17
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I once bought on eBay SMD - mount transformers made for DSL modems. They are tiny, but have 12 Henry windings, both input and output. Stacking such transformers I am getting different ratios. Then found good cases for them: bought a lot of motors made for cassette recorders.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 20th December 2011, 08:28 PM   #18
ruffrecords's Avatar
Originally Posted by Alexontherocks View Post
one of the solutions might be this:
EDCOR Electronics Corporation. PCW10K/10K
or
EDCOR Electronics Corporation. WSM10K/10K
comments?
Thanks again
Alex
The trouble with Edcor is they are relatively low inductance transformers - that's why they are cheap. The two mentioned have primary inductances of 8H and 11H respectively. At 20Hz these look like about 1K ohms rather than 10K so unless you can be sure your driving source impedance is a lot less than 1K at 20Hz you will certainly have poor low frequency amplitude and phase response as well as distortion.
Cheers
Ian
Ian
Old 20th December 2011, 08:30 PM   #19
DF96 is offline DF96  England
I have plenty of tools and machines (a friend has a CNC/metalwork shop) so forming, bending and such would not be a problem..
I understand that mu-metal loses much of its permeability when machined or bent, so it needs to be processed again after forming.
Old 20th December 2011, 08:32 PM   #20
Gluca is offline Gluca  Italy
Gluca's Avatar
I have been running 15/15B since ages ... I own 2 pairs. Good stuff.
Input transformer: floating input = distortion ErikdeBest Tubes / Valves 13 20th January 2009 09:36 AM
Designer casing Gabster Group Buys 4 8th January 2009 11:13 AM
My new Pass ONO and the use of MuMetal harryeng Pass Labs 15 19th December 2005 08:27 PM
Casing dimensions Mlaen Solid State 1 20th February 2005 06:32 PM
Mumetal For Sale planet10 Swap Meet 11 6th November 2002 07:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
