Oil-filled caps: ASC versus Panasonic - diyAudio
Old 19th December 2011, 03:07 PM   #1
Default Oil-filled caps: ASC versus Panasonic
Are there any huge (and if yes then what?) differences between those two? Digikey sells the Panasonic 50uF (part number P9669-ND) for $7.72. ASC 40uF is $19.95 over at Partconnexion. I'll be hooking up three or four of them to obtain larger values and in at least couple of amps, so the cost does play a significant role...
Old 19th December 2011, 03:26 PM   #2
GloBug is offline GloBug  Canada
Banned
Well the Panasonic is a film cap, the ASC is the oil cap.
Maybe try the Panasonic's on one amp before ordering a bunch of Oil caps from Angela's.
I just noticed the Angela Caps are only 15.99, not 19.95, so maybe you can afford them yet.
Old 19th December 2011, 03:47 PM   #3
For this particular cap (P9669-ND) they do say 'oil wound type'... Whatever that means...
ASC oil caps vs M-tube cap for ps phrarod Tubes / Valves 10 20th April 2011 06:23 PM
Oil filled caps - how are they made? DIY caps? Brit01 Tubes / Valves 18 31st December 2009 06:51 PM
oil filled caps ICAR CCR25 0,5 mF 1500Vpp mos57 Swap Meet 0 19th November 2009 10:56 PM
FS ASC oil caps kjunom Swap Meet 3 20th May 2009 08:07 PM
spearinol oil (in ASC caps) jarthel Tubes / Valves 1 29th June 2006 05:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
