| diyAudio Sponsor | ||
I have this idea of using a JFET as a Phono Head Amp for my MC Lyra Lydian cartridge (500uV). Currently I use a Musical Fidelity The PreAmp A3 (shunt power regulation, LM394 BJT matched pair head amp, and VQ1000J MOSFETs), and I want to beat it. I know that one AD797 IC as it is based on BJT's can give better S/N ratio, but I don't like to see so many transistors in the signal path... I want a minimalist design. And why not mix JFET with Tubes? First time I saw this design was in the 90's from Sonic Frontiers, when I used to buy quality components from The Parts Connection. So, I share here the Sonic Frontiers SFP-1 Phono Stage schematic (partial, due to upload space constrains) so you can comment on it. The JFET in use are marked as J310. Anyone have information on this one? +B1 AND +B2 = 210VDC (for the 12AT7 output tube and 6DJ8 RIAA driver) +B3 = 187VDC (for the JFETs) 015.jpg 016.jpg Cheers. Last edited by Jebem; 19th December 2011 at 12:30 AM. Reason: Forgot to mention the JFET references |
#2 |
J310 is a standard N channel JFET, Fairchild amongst others currently produces it. Whether or not it is quiet enough for a 500uV cartridge will require inspection of the data sheet to determine. (Google)
www.kta-hifi.net |
#3 |
Yap, it doesn't look too impressive at 3dB / 6nV to 10nV per sqrtHz... I have some much quieter (and expensive ones) 2SK146 that I can get from a local supplier (New Old Stock) that can do a better job.
#4 |
J310 makes an excellent VHF/UHF amplifier. It is an old design and may have too much 1/f noise for low-level audio.
#5 |
Jebem,
For the hybrid circuitry approach, I advise you look into Allen Wright's cascode, with SS "downstairs" and a triode "upstairs". Allen, who sadly is no longer with us, used a JFET in a single ended setup and a twin BJT in a balanced setup. AFAIK, AW's company VSE is still in business and they will sell you appropriate "sand" for the project.
Eli D. |
#6 |
Thanks a lot DF96 for Your good input (by the way, I like the "D" series valves, really... I have got a few valve portable radios from eBay UK, like Bush TR82C's or the KB RHAPSODY DE LUXE PP251 to mention but a few... it reminds me when I was 6 years old and started poking around with my dad's Philips "D" series radio... ).
Thanks a lot Eli for your suggestion. I'm learning from You that Allen has passed away... How sad. This is one big loss, as I really liked his ideas, diverging from the standard stuff. I used to visit his site some years ago, and reading his articles in Sound Practices USA magazine as well. Maybe I will test one of his circuits one of these days. Cheers, Jose Mesquita Lisbon http://sites.google.com/site/sunajeb...ificador-211se |
#7 |
OK, people, for those interested in the SFP1 guide, here is it in full glory TIFF format:
SF Phono Stage sfp1 & Signature Service Guide.zip Cheers, |
#8 |
I only got one page of it
#10 |
Funny, I just downloaded it now and I can see all the 22 pages of the service guide.
You need a TIFF display tool like Windows Photo Viewer. Sorry to ask, but did You check the left and right arrows to navigate between pages? tiff display.jpg |
| Sonic Frontiers SFP-1 mods? | rdf | Tubes / Valves | 6 | 24th December 2009 06:36 AM |
| For Sale Sonic Frontiers SFL-1 Signature Line Stage Preamp | kilohertz | Swap Meet | 0 | 7th February 2009 05:58 PM |
| Sonic Frontiers Jitterbug | eleakist | Digital Source | 2 | 11th February 2008 04:23 PM |
| Sonic Frontiers Line 2, please help? | henkel | Tubes / Valves | 2 | 23rd December 2006 04:40 PM |
| What happened to Sonic Frontiers, exactly? | KT | Everything Else | 8 | 27th May 2004 11:35 AM |
| Page generated in 0.14738 seconds (73.20% PHP - 26.80% MySQL) with 11 queries |
