diyAudio Sponsor
Old 14th September 2003, 12:32 PM   #1
Default Help with 5692 line amp
I have started work on another line amp in order to use up the 5692 red base tubes that are sitting on my bench. What I have drawn is mostly by memory(and that it fading). Would you mind taking a look at what I have got and suggest corrections and modifications please? Schematic is drawn in handicad.
I haven't done the PS yet. I do have several transformers. a 250-0-250, and a 370-0-370. I would like to incorporate several regulator tubes to achieve a B+ of 250V.
Joe
Old 14th September 2003, 01:18 PM   #2
I'm trying to send the schematic. It says the file too large?
Old 14th September 2003, 01:57 PM   #3
G is offline G  United States
G's Avatar
I had the same problem with the schematics that I drew using ISIS. Download a program called IRFANVIEW (a search on google will turn up the address. Open up your schematic with Irfanview and click on IMAGE and then RESIZE/RESAMPLE. Type in 800 in the highlighted square and hit enter. Then click on IMAGE again and then on SHARPEN. You should be able to save the image a post it at this point. When you save the image save it as a Gif. Hope that helps.
G
Gavin
Old 14th September 2003, 05:38 PM   #4
Half a dozen tries ...all failures
Old 14th September 2003, 05:47 PM   #5
it
Old 14th September 2003, 05:48 PM   #6
Whoops!!
WRONG PHOTO
Old 14th September 2003, 08:06 PM   #7
diyAudio Senior Member
fdegrove's Avatar
Joe,
If you can't resize it with what you've got just mail it to me and I'll do that for you.
Frank
Old 14th September 2003, 08:33 PM   #8
Old 14th September 2003, 09:05 PM   #9
fdegrove's Avatar
If the image is saved and blown up to 200% it is useable.
From what I see you left R7 and R9 undefined, correct?
C3 is 470µF?
C2 is 0.470µF which for most applications will likely be too small.
C1 however will be a little too big once R7 is defined...which is where you have trouble, I assume?
Frank
Old 14th September 2003, 11:36 PM   #10
May I ask what you're trying to design to? That is, how much gain, what Zo, etc.
Thanks.
SY gets jiggy (5692 measurements) SY Tubes / Valves 31 15th March 2010 02:36 AM
WTB: RCA Red Base 5692 Tax Swap Meet 0 24th April 2009 02:21 PM
5692, the best? Makofoed-6sn7 Tubes / Valves 37 24th July 2006 10:24 PM
GE 5692 BLACK base? kstylianos Tubes / Valves 31 8th February 2006 06:03 AM
Help about the 6SN7/5692 linestage BernardB Tubes / Valves 8 10th November 2005 11:21 AM
Page generated in 0.52112 seconds (17.33% PHP - 82.67% MySQL) with 11 queries
