diyAudio Sponsor
Old 11th February 2012, 03:28 PM   #21
scott17 is offline scott17  United States
scott17's Avatar
Thanks Cassiel. I wish you well in tuning your circuit.
I took a few more measurements today.
Right before the output clips I measure 70V P-P driving the input to the cathodyne, and 65V P-P driving the 6CA7s. The cathodyne B+ is 290V.
Single-Ended Tube Amp Kit
Old 24th February 2012, 07:32 PM   #22
scott17's Avatar
This is the version with a few component modifications. I mentioned before that my PT is only 200mA, so I had to further modify the cathode resistors for the 6CA7s to keep the current in check. The drivers are about 3mA each & the cathodynes are 3.5mA each.
My function generator square wave has a little overshoot, so that's where some of the overshoot comes from on the waveforms. The 1KHz waveform was taken with a 100pF compensation cap. Changing to 330pF reduced the overshoot and ringing to just about flat. I show the 100Hz waveform with and without feedback. Measurements taken at 2.83V with 8 ohm dummy load.
Old 24th February 2012, 10:41 PM   #23
scott17's Avatar
The plate load resistor for the lower half of the mu follower should actually be about 30K, not 33K.
Mu Follower to drive a Push-Pull Amplifier? Kashmire Tubes / Valves 12 26th October 2011 09:49 AM
Commercial Audio Brands: N-Ch/NPN only output devices in a push pull power follower tiefbassuebertr Solid State 0 11th May 2011 10:15 AM
Cathode follower amplifier, push-pull, xformer-coupled 00940 Tubes / Valves 3 19th November 2010 01:53 PM
Push-Pull driver stage? alexmoose Tubes / Valves 12 18th September 2006 11:38 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Page generated in 0.08013 seconds (72.21% PHP - 27.79% MySQL) with 11 queries
