Audio Note P-zero
Audio Note P-zero
Old 15th December 2011, 10:03 PM   #1
mayky is offline mayky  Hungary
Default Audio Note P-zero
Hi Everybody !
I wanna ask You: have somebody some infos for Audio Note P-zero monoblocks?
Schematics, inside pohotos, etc.
Audio Note
Old 16th December 2011, 02:08 PM   #2
piano3 is offline piano3  United Kingdom
If you have a problem with your P-zero, why not contact Audio Note directly. I am sure you will find them most helpful.
Old 16th December 2011, 06:37 PM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Nowhere does mayky say he has a P-zero. Many of us are interested in how commercial equipment is built, either for the design ideas or to make our own (for personal use) "replica". I can see nothing wrong with that.
The only issue may be publishing a copyright schematic.
Old 17th December 2011, 12:28 AM   #4
Do please excuse me; I naively assumed that publishing a copyright schematic was indeed the issue and against the forum rules- I really must read them more carefully.
What I DO know, however, as the Director of Audio Note is a friend of mine, is that they are very open and approachable and welcome any interest in their products. Peter Qvortrup would almost certainly provide a schematic for personal use.
Old 18th December 2011, 09:05 AM   #5
Well. I got some pcl82 tubes and i want to build a little amp. with this tubes.
therefore i search a good schematics. I find some, but I'm courious how to made this that BIGS. (AN)
Old 18th December 2011, 10:10 AM   #6
They use very large chassis for all of their equiptment, even DACS. Inside is mostly empty space. They never get hot.
Old 18th December 2011, 12:14 PM   #7
LinuksGuru is offline LinuksGuru  Europe
There is virtually nothing new in vacuum tube schematic since 50 - 60 (only hybrid amps are exception). Small tweaks don't need to be counted as real invention.
Even if something was patented/copyrighted, it is expired due to the age.
Old 18th December 2011, 12:52 PM   #8
patenting and copyrighting are hardly the same thing though, wouldn't you agree?
Old 18th December 2011, 05:27 PM   #9
Yes, but none of it can be violated neither for personal neither for commercial purpose.
Original (non-derivative) schematic made with some unique features/algorithms can be patented (its quite expensive process, however,), visual look (if really different from anything else on the market) is copyrighted from the moment of creation.
When it comes to vacuum tube schematic, it can be copyrighted only as picture (drawing, artwork, call it as you like), but it can't be patented because it simply put, typical, and similar solutions exist for over half of century in sheer numbers.
Original visual design (e.g. Wavac, Lars) is also subject of copyright. AuidoNote is not because it is typical for this product range, and many of this company products use industry-standard OEM boxes/enclosures.
Scanned AudioNote vacuum tube schematic can't be posted on forum because it is copyrighted material. However, you can redraw it with any software or just by hand and post anywhere.
Old 18th December 2011, 05:48 PM   #10
Charm is offline Charm  Russian Federation
http://www.audiofil.net/data/upload/...zero_be099.jpg
Apparently installation is similar to this one.
http://farm4.static.flickr.com/3013/...e464ac3463.jpg
Audio Note P-zeroHide this!Advertise here!
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 06:17 AM
Audio Note schematics EsE Tubes / Valves 0 22nd May 2006 11:10 PM
Audio Note AN-E upgrade? Sclalars Multi-Way 7 8th February 2006 11:42 AM
Audio Note P-2 Yurik Tubes / Valves 0 27th February 2004 12:11 AM
Audio Note Kageki vs. EAR 859 vs. Audio Innovations: The First Vortex Tubes / Valves 1 2nd February 2004 01:31 AM
