| diyAudio Sponsor | ||
Are transformer ratings in dBu based on the primary or secondary side? I have some general purpose Sowter input transformers rated at 11 dBu would that be the input or output level?
Thanks, Marty |
#2 |
Probably the input. Which Sowters? PRE AMP INPUT TRANSFORMERS
http://www.ecpaudio.com |
#3 |
Thanks for the reply. They are 3128 which are the same as 3678 except for no 200 ohm tap.
#4 |
The 3678 has differing level capabilities depending upon which input is used which suggests that your 11dBu rating is for the 600R input tap.
| Transformer Ratings | TheGimp | Tubes / Valves | 7 | 23rd July 2010 02:02 PM |
| transformer ratings... pls help | JojoD818 | Solid State | 32 | 23rd July 2010 10:42 AM |
| Transformer Ratings | jt1 | Tubes / Valves | 7 | 31st March 2010 09:36 AM |
| ratings of output transformer??? | cbutterworth | Tubes / Valves | 6 | 24th January 2008 03:16 PM |
| Transformer ratings??? | AR1 | Power Supplies | 2 | 2nd May 2005 07:02 PM |
| Page generated in 0.09137 seconds (57.63% PHP - 42.37% MySQL) with 10 queries |
