High power CCS
High power CCS
Old 13th December 2011, 06:34 PM   #1
db! is offline db!  Canada
Default High power CCS
I'm looking to start playing with some power tubes that require relatively high B+(700+ volts) and high currents(150+mA). I would also like to stick with a solid state design to keep the design simple.
Would any of the following designs work ?
- A typical transistor & LED/Zener reference CCS. The transistor will obviously be sized according to the voltage and dissipation.
- A whole bunch of IXYS 10M90 in parallel to deliver the required current.
Any input would be appreciated!
Old 13th December 2011, 06:53 PM   #2
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
How about a simple MOSFET CCS as plate-load, a mosfet Mu -follower...?
No need for complication, ref the gate to say, half +B coupled to gate by around 4.7M and you're done....
Just make sure the MOSFET chosen has a relatively low reverse-transfer capacitance, and use a Gate-Stopper of around 400-200 ohm in Carbon Compo, and keep the Gate connections to gate-stopper and protection zener good and short...
--Seeing you're running a fairly high current, a Plate-load resistor of only a few hundred ohms is needed--Figure dropping around 15-20V across it....
Ive had good results with this idea.....
Das Beste Oder Nichts
Old 13th December 2011, 08:36 PM   #3
SemperFi is offline SemperFi  Wake Island
I assume this is a PP output stage and the ccs goes in the cathode end. ? Then I'd go for your first suggestion.
What is the voltage available for the ccs? What tube is it?
I think u need to elaborate a little more about what u're making.
Old 13th December 2011, 09:06 PM   #4
tomchr is offline tomchr  Canada
tomchr's Avatar
IXYS 10M45 with a cascode (assuming you have the headroom) would work as well.
I see no reason a normal LED-based CCS wouldn't work as long as the devices don't see over-voltage, over-current, or SOA overload conditions. I'd probably run some sims to ensure that none of these silicon killers are present during start-up as well as normal operation. Or at least think it through...
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 13th December 2011, 09:08 PM   #5
The plan is for a CCS-loaded parafeed; B+ is around 750v or more, currents are around 150-200ma.
I am still experimenting at this stage so there isn't a formal plan. I'd at least like to get these firebottles glowing.
The tubes in question is eimac 100th and 4E27.
Old 13th December 2011, 09:39 PM   #6
DF96 is offline DF96  England
Could you use a pentode as CCS?
Old 13th December 2011, 10:25 PM   #7
Unless there is no reasonable way to do this with solid state parts, I'd like to avoid tube/hybrid CCS.
Old 13th December 2011, 10:28 PM   #8
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
How about IXYS IXTH 20N50D? Perhaps with the IXYS IXTP01N100D on top? (several parallel (not sure if that is possible) (1000V)
If you can see the speaker cone move...it's not hifi.
Old 13th December 2011, 10:36 PM   #9
piano3 is offline piano3  United Kingdom
Hello DF, can you think of any with both suitable gain and current capability of 150mA?
Old 13th December 2011, 10:40 PM   #10
Well, maybe a transmitter tetrode? These go up to very big sizes.
High power CCSHide this!Advertise here!
Which high power CCS for output stage? andyjevans Tubes / Valves 25 4th May 2017 05:28 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
Suggestions for high current CCS? dsavitsk Solid State 8 11th April 2009 04:30 PM
Power ccs hugobors Solid State 1 8th February 2008 09:06 AM
