Which one with lower noise? - diyAudio
Old 14th September 2003, 01:24 AM   #1
Question Which one with lower noise?
zener and gas tube regulator(0A2,0B2...), which one have lower noise level?
Old 14th September 2003, 02:27 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Zener, especially because you can throw a lot of capacitance across it and it won't explode itself in exactly three seconds (...depending on RC time constant...). It has a positive, not negative resistance characteristic, so is stable. With adequate ratings, it also has more current capability.
For most applications, noise won't matter. If it does, make a circuit with lower PSRR
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 14th September 2003, 08:00 PM   #3
diyAudio Senior Member
fdegrove's Avatar
If the glowdischarge tube doesn't have to do more than, say 20mA I'd much more prefer the tube over the zener string...
The only decent Zzzzzzeners I know of are the 5 Volters which are rather useless for tubed circuits.
Any noise left on a glow tube is much more spread across the audioband whereas zeners tend to throw alot of HF noise.
While I can hear the unpleasant presence of zeners in a circuit I can't hear any unpleasant sound I could attribute to the glowdischarge regs.
Besides, on a silly sidenote, aren't these glowers absolutely charming to watch in a dimmly lit room?
Frank
Old 14th September 2003, 08:10 PM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
With enough 5.4V ones in series, the zeners win. High voltage zeners are noisy and have a poor temperature coefficient.
As Tim says, you can slug zeners with c.
Really, each has it's own set of problems.
Old 14th September 2003, 08:14 PM   #5
fdegrove's Avatar
300V with 5.4V zeners would require 55+ zeners in series...or two OA2s.
My choice is made...
Frank
Old 14th September 2003, 09:10 PM   #6
Sch3mat1c's Avatar
Or 1 0G3/medium-volt zener, a <pentode RF amp type> and a <pass tube>...
Tim
Lower rails for lower impedance? 95Honda Solid State 7 19th December 2007 08:59 AM
What makes an amplifier have a lower noise floor? pjpoes Solid State 27 2nd July 2007 12:20 AM
KT-88 Ella amplifier, how to lower noise? jlharden Tubes / Valves 12 17th January 2007 05:11 PM
L-Lower? oliverh Pass Labs 12 23rd August 2006 04:25 PM
Zen with lower voltage? DorcyDuck Pass Labs 9 20th April 2004 05:02 PM
Copyright 1999-2017 diyAudio
