| diyAudio Sponsor | ||
I need a source and part number for some bias test points that you would insert your VOM probe into. I've seen them but cannot recall a PN or name. They are mostly plastic with a metal insert inside and are chassis mount.
#2 |
They're called tip jacks. The best ones are made by HH Smith (Abbatron). I buy them on eBay. Search for HH Smith or tip jack. Mouser also sells them. But they may be imports.
Mouser Electronics - Electronic Component Distributor tip jack
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University Last edited by HollowState; 12th December 2011 at 11:09 PM. |
#3 |
thanks
#4 |
Just happened to find some NOS H.H. Smith Turret terminal banana jack pieces at a .24 ea close out price.
Now I'm trying to find some nylon stepped washers outside dia 1/2" inside dia .312 height at max step .092 thickness of washer .062 |
#5 |
Try McMaster-Carr for shoulder washers.
| A30 hardware | Buhl | Pass Labs | 10 | 9th December 2010 09:32 AM |
| DIY hardware | polkymon | Multi-Way | 2 | 5th March 2007 01:01 AM |
| Hardware?? | lpd | Tubes / Valves | 5 | 6th March 2005 03:36 PM |
| Designer Hardware | Hagbard | Multi-Way | 8 | 6th February 2004 06:37 PM |
| Page generated in 0.12144 seconds (49.94% PHP - 50.06% MySQL) with 10 queries |
