| diyAudio Sponsor | ||
I'm looking for a good source for chassis.
#2 |
Hammond?
#3 |
or something like this?
#4 |
Large footprint, and also deep, unfinished aluminum bake ware, as used in commercial kitchens, is a surprisingly good value. Don't use thin walled or coated stuff, which is what you'll find at WalMart.
Eli D. |
#5 |
I use these guys: Amp Chassis
They will make you custom chassis to order, and are very reasonably priced. Far sturdier than the Hammond or Bud stuff particularly if you specify 0.080" thick aluminum and welded corners. I highly recommend them and use them for all of my projects now. See the thumb nail for an example of some of their custom chassis in use.
www.kta-hifi.net |
#6 | |
Damn! That is VERY sharp pricing and a good looking functional product. Pity they don't ship to The Shire...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#7 | |
www.kta-hifi.net |
#8 |
I sell these on eBay if anyone is interested. The website isn't working as a sales portal.
Yaeger Audio Jon |
#9 |
I've used Dirty Dawg aluminum chassis's for my last 3 amp builds.
Outstanding! The chassis's I mean.............................................. .......................... Steve |
#10 |
I second Eli's suggestion. Get thee to a local cake decorator supply store and find a variety of professional aluminum cake pans. I have used both Wilton and Fat-Daddio's. The middle sizes run $18-25 (USD).
The Wiltons are very straight-sided with sharp 90 degree corners. The Fat-Daddio's have slightly smoothed corners and edges and create a "softer" look. The aluminum is sturdy and supportive, moderately easy to punch and easy to drill. A couple of random links: Fat Daddios pans Wilton professional pan The 2" deep pans are what I normally use. There are some 3" and 4" deep pans out there, but they are not all that common in local supply stores. And you're on your own to make a bottom plate if you want one. I usually add feet to the corners of the inverted pan. I'm planning to experiment with some wood edging that will keep these chasses from looking like . . . well, like cake pans.
| Tube amplifier chassis damping | rastanearian | Tubes / Valves | 11 | 22nd September 2010 04:17 PM |
| Chassis for DIY MonoBlock Tube Amplifier | sgerus | Swap Meet | 1 | 20th January 2009 07:40 PM |
| best cheap tube phono chassis for mods? | KBK | Analogue Source | 2 | 9th May 2008 06:29 AM |
| Mirror tube chassis | Simpleton | Everything Else | 5 | 24th March 2005 01:02 PM |
| Tube/Transformer Positioning on Chassis | trustalbini | Tubes / Valves | 30 | 20th April 2003 11:24 PM |
| Page generated in 0.23805 seconds (36.19% PHP - 63.81% MySQL) with 11 queries |
