diyAudio Sponsor
Old 10th December 2011, 04:54 PM   #1
Default Lightbulbs as ccs
Has anyone used ordinary incandescent light bulbs as ccs in their tube amps?
Old 10th December 2011, 04:58 PM   #2
Frequency response DC to , well maybe 2 or 3 Hz within a few dB kinda says it all.
Old 10th December 2011, 05:00 PM   #3
Yvesm is offline Yvesm  France
Yvesm's Avatar
Not yet !
Just as load for Mosfets . . .
In the very old time, it was common to add a small light bulb in parallel with the loudspeaker to produce some "expander" behaviour !
Yves.
Old 10th December 2011, 05:59 PM   #4
Soonerorlater's Avatar
Wow, Far out man, that was me in the 70's!...........
Old 10th December 2011, 06:17 PM   #5
I've been thinking, the light bulb has been in and out of audio/visual electronics for more than 25 years. I first saw it as a troubleshooting tool for high voltage DC switch-mode regulators in televisions back in the late 80's. Peavy prototyped an eq that had light bulbs on each tuning frequency to show peaks in the audio signal as a tool to spot positive feedback (was changed to leds in final design because of recovery time). crossovers used one to protect horns in stage monitors (still used today, but on below 500W designs). Guitar amps from time to time have them, but they were solid state based. and I saw the zen amp designs just a few minutes ago.
Old 10th December 2011, 06:18 PM   #6
I wonder if someone has took a futterman otl, substitute the bottom row with lightbulbs.
Old 10th December 2011, 06:26 PM   #7
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
I have played with the thaught of using some GM70 tubes (filament) for a DeLite-amp...(or Zen..)
Arne K
Ars longa, vita brevis
Old 10th December 2011, 07:02 PM   #8
Not yet, but doing some back of the envelope calculations with small (10W at 220V) bulbs they may actually sort of work. At 220V a 10W has about 5k resistance, pulling 45mA. Parafeed EL84?
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 10th December 2011, 07:41 PM   #9
light bulbs where used as plate load for tube burn in . a very bright bulb would indicate a shorted tube
Old 10th December 2011, 07:57 PM   #10
tomchr is offline tomchr  United States
tomchr's Avatar
An ideal CCS (Constant Current Source) has infinite output impedance. A small light bulb will be a few hundred ohms -- pretty darn far from ideal. So for a CCS, it's not a good candidate.
Used as a plate load for wonky distortion effects may be another story.
~Tom
"50 % of the game is mental and the other 50 % is being mental. I've got that part down, no problem."
http://www.neurochrome.com/audio
2SK82 + Lightbulbs = Fun Michael Rothacher Pass Labs 52 4th December 2011 03:30 PM
Fun with Lightbulbs and the SOZ... opc Pass Labs 29 31st January 2007 06:34 AM
Inductors, Lightbulbs As Current Sources Michael Rothacher Pass Labs 39 4th March 2006 01:44 AM
Page generated in 0.20165 seconds (39.81% PHP - 60.19% MySQL) with 11 queries
