diyAudio Sponsor
Old 9th December 2011, 05:28 AM   #1
Smile XFMR Help?
First Post!!!! Hurrah!!!!
I am wanting to put one of these in a tube drive I made for creative purposes.
I want to know the ratio of the transformer and where to find a cheapo/medium priced candidate.
Any help identifying what's inside this puppy would be helpful.
It's just female XLR-XFMR-male TS jack.
Heres the spec link:
http://www.eu.audiotechnica.com/en/r...202_cp8201.pdf
It says 250 ohm to 50K. So does that mean its a 1:200 ratio?????!!!!!!
That sure doesn't sound right
Thanks in advance.
Old 9th December 2011, 10:04 AM   #2
EssB is offline EssB  United Kingdom
That link doesn't work.
What you describe sounds like an inline microphone transformer designed to connect a low impedance balanced microphone to a high impedance unbalanced mic input.
If it's really 250 to 50K then the turns ratio will be approx 1:14 because the impedance ratio is the square of the turns ratio.
Old 9th December 2011, 12:38 PM   #3
Thanks so much EssB!!! Cheers!
PWR XFMR wiring skipper Tubelab 6 15th March 2011 04:17 AM
Power XFMR Choice sherpa Tubelab 3 18th October 2010 09:05 AM
MC Step-up Xfmr and SNR analog_guy Analogue Source 13 13th January 2010 04:30 AM
Anyone have SPICE models for PSU Toroidal Xfmr ?? 13DoW Power Supplies 49 2nd April 2007 04:01 PM
rectification and xfmr stress beamnet Tubes / Valves 16 19th September 2005 03:51 PM
Page generated in 0.08784 seconds (62.48% PHP - 37.52% MySQL) with 10 queries
