diyAudio Sponsor
Old 8th December 2011, 08:16 AM   #1
renton1 is offline renton1  Germany
Default PSU for Aikido (4x 12SN7)
Hello,
I´ve just purchased a pcb for an octal Aikido and want to use four 12SN7. Unfortunately no power supply is provided.
Can anyone recommend a regulated psu for this build. Heating shall be done with DC. B+ at 300 V.
Which cap values are you using in the audio circuit?
Many thanks and best,
Renton
Old 8th December 2011, 09:25 AM   #2
beetel is offline beetel  Singapore
Classic Valve Design - Surplus / Single-Run / Clearance / Ooopsies
2nd Aikido PCB and PSU groupbuy
Old 8th December 2011, 09:47 AM   #3
Thanks for the ling. Would be the PS-1 the better option? PS-1 High & Low Voltage Regulator Kit
Old 8th December 2011, 11:34 AM   #4
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Yes I think it would be better. I designed my psu to be a bog standard psu version just so that people would have something to start off with.
Old 8th December 2011, 12:26 PM   #5
Doesn´t it get too close to the max. ratings? 2.5 A heater current @ max., 2.4 A heater current for the 12SN7.
Old 8th December 2011, 12:30 PM   #6
The PS designed by Bas uses tube rectifier and pcb cost is only $9.50.
Old 8th December 2011, 12:34 PM   #7
Not sure, what´s gonna be build. My question was regarding the PS-1.
Old 8th December 2011, 12:39 PM   #8
The 12SN7 has a 300mA heater. So the 2.5A max heater regulator supply is fine.
Old 8th December 2011, 12:58 PM   #9
Yes, but if i´d go the 12,6 V route, the maximum Amperes of the PS1 will only be 1,25 A. So says its pdf.
Old 8th December 2011, 01:31 PM   #10
Ok. Either way it is inside the rating. Therefore the PS seems suitable to me.
WTB: Want to buy 4x PSU Caps 15000uF 100v Epcos, Rifa, for Adcom GFA 555ii bandolino Swap Meet 3 29th December 2010 04:02 PM
modelling PSU for Aikido cbutterworth Tubes / Valves 16 1st December 2007 03:21 PM
New PSU for Aikido? cbutterworth Tubes / Valves 5 6th September 2007 01:03 AM
WTB: Aikido PSU habsrock93 Swap Meet 23 13th July 2007 11:23 PM
Aikido PSU help cbutterworth Tubes / Valves 48 13th October 2006 07:54 PM
Page generated in 3.61216 seconds (3.11% PHP - 96.89% MySQL) with 10 queries
