diyAudio Sponsor
Old 6th December 2011, 10:40 PM   #1
SS64 is offline SS64  United States
Default Craftsmen RC-2
I picked up this little amp at a local hamfest for $20. It appears to be un modded and in good shape. All the tubes check good.. No shorts and good emission. Ok here's the problem though... At low volume it sounds good, but as i increase the volume the sound becomes distorted. I know the speaker is good and it is on the right ohm connection..
What do you guys think? Maybe the 70 year old output transformer is going south?
It isn't fun unless it can kill you!
Old 6th December 2011, 10:54 PM   #2
GloBug is offline GloBug  Canada
Banned
Re-cap it and go from there. OPT likely fine.
Old 6th December 2011, 10:59 PM   #3
Banned
Here's a drawing if you need it.
Hawthorne Audio • View topic - Hi Everybody / Help
Have fun.
Old 6th December 2011, 11:01 PM   #4
Ok ill slap some in there for temporary to see if it fixes it..
Anybody have a schematic for it?
Old 6th December 2011, 11:06 PM   #5
Banned
Look above.
Old 6th December 2011, 11:54 PM   #6
thanks. I must have posted when you did.
Old 7th December 2011, 12:00 AM   #7
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
For convenience:
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 9th December 2011, 12:39 AM   #8
Dyna Saur's Avatar
Thumbs up Craftsmen RC-2
Over the years, I have owned three of these amps, they're decent sounding, approximately 10 watts out. Nothing special, just a basic 50s era 6V6 PP amp design.
The caps - ALL of them, signal path as well as power supply electrolytics - should be replaced, as these units are about 60 years old. RCA never intended these things to still be in use after six decades.
/ed B in NC
real radios glow in the dark
Old 9th December 2011, 01:09 AM   #9
Wavebourn's Avatar
Do you mean RCI, or RCA?
anyone have experience with a Radio Craftsmen C400? chicagozer Tubes / Valves 0 15th February 2011 05:46 PM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
C450 Radio Craftsmen info needed pliedtka Tubes / Valves 2 7th April 2010 04:38 PM
RE: RC-19 or RC-30 chungtat Tubes / Valves 6 6th August 2005 03:51 AM
Craftsmen in Toronto? bigerik Multi-Way 5 18th January 2005 01:38 AM
Page generated in 0.13477 seconds (62.20% PHP - 37.80% MySQL) with 10 queries
