| diyAudio Sponsor | ||
I have a conversation with a fellow, and he said that someone out there has made a SE driver circuit for 845 that is SRPP driver with parafeed interstage transformer, what is this about?
I try to do a search but no one has made such circuit, but I actually found some transformer winder has said that "at para feed or feed mode is parallel to the transmitter, decoupled with a capacitor in parallel to the tube. The task of the working resistance takes on either an anode choke (choke load) or an additional tube (SRPP)." Since all my friend has build a driver with parafeed transformer that offer by bottlehead and a pure SRPP circuit capacitor coupled. Never heard of SRPP tube with parafeed transformer coupled, this is kind of weird. Can anyone tell what is this about? |
#2 |
SRPP is for driving a fixed known resistance. If this resistance is very high then the 'SRPP' is actually just a grounded cathode amp with an active load, not an SRPP. Generally, an output grid is either a high impedance (so not really SRPP) or (if grid current is drawn) a very variable resistance (so SRPP not suitable). I conclude that SRPP is not the appropriate circuit to use for this purpose, despite its popularity.
| 6AS7 Parallel Feed Amp | lcsegeng | Tubes / Valves | 7 | 9th August 2008 02:17 AM |
| Built the DDDAC MKII USB audio card, modified it to feed SRPP tube amp line stage | wa2ise | Tubes / Valves | 0 | 8th June 2008 03:21 AM |
| Adding a parallel feed on DRD | eeyore | Tubes / Valves | 1 | 11th July 2007 04:57 AM |
| Magnequest B7 parallel feed transformer for sale | MiaTele52 | Swap Meet | 3 | 16th January 2006 03:42 AM |
| Parallel feed OT | Bas Horneman | Tubes / Valves | 25 | 12th February 2003 02:07 PM |
| Page generated in 0.34322 seconds (17.82% PHP - 82.18% MySQL) with 10 queries |
