diyAudio Sponsor
Old 6th December 2011, 09:54 AM   #1
quan is online now quan  Australia
Question opera consonance phonostage-PM1
Hi , i am totally new to the tube side of the world ie high voltage and nasty shocks.
I am asking for suggestions what to do to improve the phonostage. The circuit is based on one ECC83 triode per chanel. The excerpt stated that RIAA equalisations work as active,frequency dependent feedback between amplifier output and the cathode of the first valve.
In stock form- i would say -flat and lifeless. I did change the tubes for RCA but little improvement and change the bypass capacitor at output with Mundorf cap. I have no schematic on hand. I am thinking about changing a few parts on power supply ,but no idea what to do next.
Any suggestions greatly appreciated.
Quan.
Old 6th December 2011, 10:31 AM   #2
Having some problem with uploading some pictures
Hmm.
Quan
Old 6th December 2011, 11:58 AM   #3
SY's Avatar
Originally Posted by quan View Post
I am asking for suggestions what to do to improve the phonostage. The circuit is based on one ECC83 triode per chanel...
Build a new one. I'm not being flippant, single-tube ECC83 stages are hugely compromised. I don't knows yours, but every other one I've ever seen uses one of two circuits, both of which were designed and suitable for cheap console stereos in the 1950s and 60s. The sad reality is that it takes a minimum of two tubes (3-4 sections) per channel to get a decent RIAA stage.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 6th December 2011, 07:20 PM   #4
Thank you, yes i have thought about it. I just feel it is probably out of my depth at this stage to build one. Obviously kit set would be the way to go as well as learning. By the way i always thought less is better.
Quan
Old 7th December 2011, 07:58 AM   #5
Here we go again, trying to upload the pictures. But no luck.
turntable accessories for Opera Consonance LP5.0 ksporry Analogue Source 2 17th July 2011 08:05 AM
MingDa MC845-C or Opera COnsonance Reference 9.9 ksporry Tubes / Valves 4 11th February 2011 02:06 PM
Opera Consonance M500 mkii Pahstv Tubes / Valves 1 15th January 2011 11:21 AM
Opera Audio Consonance Droplet CDP 5.0 miligor Digital Source 1 12th February 2009 06:30 AM
Opera Audio Consonance Ref CD2.2 MKII CD player for sale noyan Vendor's Bazaar 1 15th June 2008 11:13 AM
Page generated in 0.13638 seconds (55.17% PHP - 44.83% MySQL) with 10 queries
