diyAudio Sponsor
Old 12th September 2003, 07:12 PM   #1
jim is offline jim  Belgium
Question E180F triode-strapped.
I'm looking for curves of a triode-strapped E180F/6688.
Can any of you guys help me ?
Jim
Old 12th September 2003, 11:22 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Hmmm...A TL preamp fan in the making?
Google turned up zip, Jim?
Maybe TL himself can help you out here...
If I find useful stuff I'll let you know.
Frank
Old 13th September 2003, 01:19 AM   #3
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Here you are (it doesn't look as bad once you zoom in on the saved image):
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 13th September 2003, 04:29 AM   #4
elib is offline elib  China
here is a Russian version of E180F,
http://klausmobile.narod.ru/testerfiles/6j9pe.htm
Old 13th September 2003, 02:57 PM   #5
Thank you all.
I'm going to use it in my PP807 amp.
E180F -> 5687(split load) -> 807(pentode mode).
Jim
Old 15th September 2003, 02:37 PM   #6
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Anyone have an opinion on what a E180F/E280F sounds like in triode mode?
TIA,
Bas
Old 15th September 2003, 02:42 PM   #7
fdegrove's Avatar
Hi Bas,
Don't I've ever tried the E280F but the E180F sounds very good, detailed and with very well focussed imaging.
I use that one now instead of the EF86...I still have some TFKs...
Frank
Old 15th September 2003, 03:17 PM   #8
Hi Frank,
Thanks..Oneday I shall build a 2a3 se amp..and I was thinking of driving it with something "unconventional" ...
Anyway..this future project will be the first where I will really listen and try out different drivers.
In the past I just used a 6n1p..but since tube o snobs hate this tube..I want to try lot's of goodies..and hear for myself.
Want to build a sort of experimenters platform with say a resistor, choke, and CCS... for the driver stage...and switch between say, 6SN7, E180F triode, E180F penthode..bla, bla, bla..
Bas
Old 15th September 2003, 09:54 PM   #9
Brett's Avatar
Also, does anyuone have an opinion o the Russian ones?
Old 15th September 2003, 10:13 PM   #10
When I used it, one careless tap and it would ring for hours. Check for microphony!
6JC6 triode strapped? Bing Yang Tubes / Valves 4 21st February 2009 10:59 PM
Triode strapped tetrode nhuwar Tubes / Valves 5 7th May 2007 02:08 PM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 01:36 AM
5763 Triode Strapped wrenchone Tubes / Valves 3 5th August 2006 07:59 PM
6L6 Triode strapped amp suggestions bobhayes Tubes / Valves 8 28th September 2005 07:37 AM
Page generated in 0.10245 seconds (78.88% PHP - 21.12% MySQL) with 11 queries
