| diyAudio Sponsor | ||
I notice there is room for 4 JAN 6418 tubes on the board but only 2 supplied.
Would it be any advantage to using the 4 tubes instead of the 2? The pots are 47K and I would like to move off the board and mount the standard type to the front of a case, are they linear or audio taper type? Any brand names I should stick with? PeterC. |
| 6418 tube preamplifier - Oatley Electronics | imagios | Tubes / Valves | 33 | 6th May 2012 02:26 AM |
| Thoughts on Oatley K282 Valve Preamp? | Maxwell Smart | Tubes / Valves | 17 | 11th December 2011 09:44 AM |
| Space between power tubes | CarlyBoy | Tubes / Valves | 7 | 9th January 2007 03:03 AM |
| Guitar Amps, Overdrive Pedals, and Space Charged Tubes | Turbo7MN | Tubes / Valves | 14 | 13th November 2006 11:38 PM |
| low voltage tubes (space charge, etc.) for guitar amp? | needtubes | Tubes / Valves | 4 | 31st October 2003 12:45 AM |
| Page generated in 0.32920 seconds (13.77% PHP - 86.23% MySQL) with 10 queries |
