| diyAudio Sponsor | ||
Winding is open somewhere between the 125V tap and the 150V tap. I have bridged both taps and secondary voltages seem OK. It does buzz a little, very little....I have to bend down and get my ear close to it to hear the buzz. That may be normal - transformer is old. It doesn't overheat (unloaded). Primary sees 230V (240 tap). Should I worry? Will it fail on me?
#2 |
the buzz may indicate a shorted winding. I'd take a cautious approach and rebuild or ditch it... Fires are expensive.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#3 | |
I don't know how some PT's work, I mean I don't understand how the primary can work with all those voltages with only one winding. Am I right if I assume that the 240V tab now it is a 215V one?
#4 | |
You can look into the side of the paper sections to see if you find this break...you may get lucky and be able to repair it... Chris Last edited by cerrem; 2nd December 2011 at 03:11 AM. |
#5 |
Yes, I did that before posting. No luck - no access to the break point.
#6 |
Yes. The slight buzz may be caused by having 230v on what is now a 215v primary. The magnetic core may be saturating on the peak voltage. Do you have access to an oscilloscope? If you do, check the waveform on the secondary winding with a light load. If the sinewave is flat topped then you need to reduce the input voltage somehow to 215v. A wirewound resistor will do the trick. The value depends on the load to the transformer. Once done, it'll be fine.
#7 |
payitforwardeddie - Thank you very much.
#8 |
| Using primary as the secondary winding in the power transformer. | mishak | Parts | 10 | 30th May 2010 05:55 AM |
| WTB 2X70V or 140-0V 50-80VA power transformer with 120V primary | gaborbela | Swap Meet | 0 | 28th March 2010 03:49 PM |
| Using transformer primary as an autoformer | stoolpigeon | Everything Else | 8 | 22nd April 2007 06:17 AM |
| transformer primary windings Q | AndrewT | Power Supplies | 6 | 28th October 2006 11:51 AM |
| Multiple primary power transformer question | trombone | Tubes / Valves | 7 | 23rd May 2005 04:36 PM |
| Page generated in 0.11453 seconds (63.82% PHP - 36.18% MySQL) with 11 queries |
