| diyAudio Sponsor | ||
On my KT88 SE that I built I was using a new EH5U4 rectifier and I noticed that my very over-kill power transformer was getting very warm. I replaced the EH5U4 with an old RCA 5U4 and the PT no longer ran hot. I also used a russian 5U3C and it ran cool. It also sounded fantastic with the russian tube. Any ideas why the EH5U4 would cause to heating problem where the same tubes of different makers did not?
My stuff: MC30, MC225, MX110, PAS3, ST-70, RH-84, HK A224 and a lot of parts waiting for time. |
#2 |
Voltage, current measurements? "Sounded fantastic" doesn't give me numbers like the power dissipation of your transformer.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 | |
Check heater current difference and voltage drop across the tube / B+ voltage level and see if there is a difference between tubes.. Regards M. Gregg
What is the sound of one hand clapping? |
| 5C8S rectifier psud2 modle/rectifier information | ryuji | Tubes / Valves | 1 | 14th March 2011 04:54 PM |
| converting tube rectifier to solid state rectifier. | tubo | Tubes / Valves | 26 | 24th December 2009 12:12 AM |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Page generated in 0.07558 seconds (78.71% PHP - 21.29% MySQL) with 10 queries |
