diyAudio Sponsor
Old 1st December 2011, 08:15 AM   #1
pingfloid's Avatar
Default What would be the correct output cap for this OTL Headphone Amp?
This amp sounds great, and it can perfectly drive the Sennheiser HD-650 headphones. But the bass is rolled off, probably because of the low value (40 uF) of the output cap. What could be a reasonable value? 220 uF? I will have to replace it with an electrolytic cap, because there is no space for an oil cap.
The values in red is what I have measured
Another issue is that it gets extremely hot. I guess that it is the cathode resistor (1k/25W). Next week I will borrow a thermal camera and I will have a hot look at it.
Old 1st December 2011, 08:26 AM   #2
Try to add anotherone in paralell and check if performance is getting better.
There´s some reasonably priced speaker crossover PP caps around.
Old 1st December 2011, 10:14 AM   #3
Beautiful wires making Really Good!!
Old 1st December 2011, 11:41 AM   #4
pingfloid's Avatar
A closer view:
Old 1st December 2011, 12:25 PM   #5
But to remind 90degree is not a good idea in wires and signal wire @@
Old 1st December 2011, 01:56 PM   #6
WOW, nice, but as briansune says 90 not recomended!
tubes.rs
facebook.com/tubes.rs
Old 1st December 2011, 04:18 PM   #7
kevinkr is online now kevinkr  United States
kevinkr's Avatar
Not an issue at audio frequencies. Nice layout, and very well executed. (Relatively speaking)
www.kta-hifi.net
Old 1st December 2011, 10:12 PM   #8
ruffrecords's Avatar
250uF will give you 3dB down with 32 ohm headphones. If you want 1dB down at 20Hz then you will have to double that.
Cheers
Ian
Ian
Old 1st December 2011, 10:13 PM   #9
pingfloid's Avatar
This 90 deg issue, could i be the reason why I am listening to a local FM radio when I use this amplifier on my house (not in my office), even with the volume pot turned down?
Old 1st December 2011, 10:15 PM   #10
pingfloid's Avatar
Cheers
Ian
Hi Ian. Thank you for the information.
I am using 300 Ohm headphones (Sennheiser HD-650).
Is there some formula for caltulating the otuput cap? I would like to learn the maths
6N1P and 6N6P OTL headphone amp orson1956 Tubes / Valves 13 24th May 2012 10:09 AM
HEADPHONE AMP TUBES NOS OTL claudiomas Swap Meet 0 21st August 2011 04:41 PM
is it correct to calculate OTL? sam8888ysl Tubes / Valves 15 26th November 2007 05:48 AM
OTL Output Cap Question Andrewbee Tubes / Valves 6 12th January 2004 07:45 AM
OTL 6L6 headphone amp-idea+need help trespasser_guy Headphone Systems 16 25th March 2003 01:26 PM
Page generated in 0.21751 seconds (40.77% PHP - 59.23% MySQL) with 11 queries
