Best Valve pre-amp match for ME 550 amp
Closed Thread
Old 16th January 2013, 05:47 AM   #121
TigerScent is offline TigerScent  Australia
...sounds like I am going to have to audition the ME25..., after hearing that valve preamp buffer - its motivating me to audition the ME25 preamp - after hearing the greater potential of the ME550 with the valve preamp -
Old 16th January 2013, 08:19 AM   #122
MrRogers is offline MrRogers  Australia
MrRogers's Avatar
Tiger, why not make your life a little easier by getting an ME25 for your ME550 or swapping your ME550 for an ME50 / ME75 and a valve preamp of your choice?
You'll be much happier with that combination and you'll get Zaphod's approval. Deal?
Old 16th January 2013, 10:07 AM   #123
Its unfortunate that our friend Zaphod is getting somewhat anxious by this whole affair, which in fact is a pioneering spirit destined to be initiated 'outside the square' of convention..., and was not forseen in its inception of having the potential to create what appears to be severe 'angst' to our friend Zaphod.
I did rather enjoy the valve preamp sound from that very 'budget' buffer amp tho, however I do suspect that the ME25 will sound better. I will just have to audition it and hear for myself...The ME550 is rather good I must say, and I have not played it, only once or twice, since I had it refurbished and modified to be more like an upgraded model by Peter Stein.
The valve buffer does its magic in the NAD T773 rather well though, transparancy and soundstage is quite good and clear, the ME550 just does it better...
Old 17th January 2013, 01:35 AM   #124
Just tried using the NAD T773 (front-main stereo channel) pre-amp connected to Guanzo Valve Buffer and ME550. LP disc sounds crisp, clear and detailed - very CD like - in fact it sounds more like a CD - than a CD - in terms of detail and dynamic crisp presence etc... like a boron, ruby or diamond cantelever feel to it...
I did modify a few things tho on the first valve buffer which is what I used this time
Be interesting to compare with ME25 ..., I imagine it would reveal a more airy soundstage with dynamic realism and inky black background silence ... hmmmmm
Old 17th January 2013, 03:20 AM   #125
...on playing a few LP's, some sound amazing, others sound tinny - odd : I need to look into this more deeply...Its become quite an issue now...What could be causing the variation?
Old 17th January 2013, 03:35 AM   #126
Zaphod Beeblebrox is offline Zaphod Beeblebrox  Australia
The ME550 is completely accurate. In computer parlance: GIGO. (Garbage In, Garbage Out)
Old 17th January 2013, 03:36 AM   #127
lordearl is offline lordearl  Australia
Perhaps changing the buffer/preamp too frequently? Either that or schizophrenia.....
Old 17th January 2013, 03:51 AM   #128
...must be the recordings...; or because of the variation in impedance, could some sounds/frequencies be more dominant than others?
...well, I have to be honest with my observations --- and they were two effects when combining the NAD T773 pre-amp with valve buffer with different LP's.
...anyway, just very loose experimentation while awaiting the ME25, and valve pre-amp kits to arrive and be put together and auditioned with transformer coupling to lower impedance and compare. The valve buffer on its own was still a very interesting result. Its early days yet for a defined conclusion.
Old 17th January 2013, 07:09 AM   #129
ahhhh, thats better --- it was just an adjustment consideration I didnt make --- sounds quite good now
...doing an A/B with the NAD main amp and ME550 : in that setup with NAD preamp/valve buffer, the ME clearly is more dynamic, crisp and meatier sounding...
Goes to show that the ME 550 will still sound better even when not optimally matched impedance wise...I quite like the ME --- I must say --- worth having !!
Old 17th January 2013, 07:52 AM   #130
OK, I also did an A/B with-and-without the valve buffer connected to the preamp out, and the difference was like chalk and cheese. Clearly, the valve buffer improved the sound considerably; there was much more presence, realism, transparancy, detail and sense of natural timbre in the sound. The midrange and top-end extended - with greater realism in vocals, while the boomy bass tightened. This is why I am so keen on incorporating valves....
Closed Thread
Best Valve pre-amp match for ME 550 ampHide this!Advertise here!
Best type of pre-amp for valve/tube power amp elgee Tubes / Valves 10 11th November 2011 10:40 AM
any advice on how to match a headphone level output to valve amp input levels? mondogenerator Headphone Systems 1 18th December 2009 03:08 AM
what guideline to match pre and amp? milen007 Tubes / Valves 5 2nd June 2008 05:58 AM
Valve Pre Amp & Class D Power Amp Puffin Tubes / Valves 7 16th June 2006 04:41 PM
