Best Valve pre-amp match for ME 550 amp - Page 17 - diyAudio
Old 24th January 2013, 01:51 AM   #161
MrRogers's Avatar
Here in Australia:
http://www.csv-group.com/index.htm
Old 24th January 2013, 04:50 PM   #162
Originally Posted by MrRogers View Post
...anywhere online?
Old 28th January 2013, 01:01 AM   #163
PVanes are rather expensive; I was looking for low-cost : gr8 sounding valves ...
Old 28th January 2013, 01:02 AM   #164
Zaph : I feel somewhat flummoxed that there is no further response regarding the auditioning of the ME25 from you re: your offer, since I accepted it. Have you had a change of mind?
Old 28th January 2013, 11:51 PM   #165
No. The offer remains. I need to locate a suitable packing box, measure, weigh and calculate postage. I will do so when I have the time.
Old 29th January 2013, 02:18 AM   #166
Oh good - fabulous - I will be able to compare and contrast to what I have to date tried - I look forward to it ....
Old 1st March 2013, 10:15 AM   #167
MrRogers's Avatar
What's the latest news, tiger?
Old 13th March 2013, 08:37 AM   #168
Im looking at the basic shuangang cryogenic for value for money for the valve preamp...
...in addition, an old schoolchum who is now an electronics engineer I briefly spoke to, suggested that I use a SS buffer with the valve preamp to bring down the impedence without compromising the upper end, as using transformers would typically do...., a helpful well-meening chap; I need to discuss this with him in a bit more detail...
Old 6th May 2013, 08:06 AM   #169
thoglette's Avatar
......., a helpful well-meening chap; I need to discuss this with him in a bit more detail...
Like exactly what is the point?
If you are happy with sound of silicon why bother with a valve?
Either get a decent transformer (eg. Sowter or Lundhal etc) or spend similar money building a quiet power supply for your op-amps.
Or go the Nelson Pass route and use a pair of matched transistors.
(either of the silcon options will be better with battery power supply as long as you don't mind recharging batteries).
Old 6th May 2013, 08:29 AM   #170
MrRogers's Avatar
That's too easy.
There needs to be a challenge, for an audiophile.
Best type of pre-amp for valve/tube power amp elgee Tubes / Valves 10 11th November 2011 10:40 AM
any advice on how to match a headphone level output to valve amp input levels? mondogenerator Headphone Systems 1 18th December 2009 03:08 AM
what guideline to match pre and amp? milen007 Tubes / Valves 5 2nd June 2008 05:58 AM
Valve Pre Amp & Class D Power Amp Puffin Tubes / Valves 7 16th June 2006 04:41 PM
Copyright 1999-2017 diyAudio
