| diyAudio Sponsor | ||
Just a quick question..
What was the graphite ring (looked like aquadag..a line that went around the tube base about half an inch up the bottle) that was put on the outside of glass on some sweep tubes for? I have seen them arc across it..I can't find any pictures and I am sure it was connected to one of the pins on the bottom of the tube.. Curiostiy has the beter of me again I think this is close: http://www.google.co.uk/imgres?q=pl5...1t:429,r:9,s:0 Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 28th November 2011 at 02:03 PM. |
#2 |
Banned
RF shielding?
#3 |
It's to prevent the "Barkhausen effect" I think. My Pye LV20 has one such tube.
"To err is human.. to make a real balls-up requires a computer" |
#4 |
When a high voltage is placed on the anode the glass insite will be charged.
The other pins of the bottom in the tube will "see" that charge and a very small current wil flow. This current can reach the G1 and the cathode. Now your settings are not correct anymore. This ring is a barrier for this effect. |
#5 | |
Thanks missisippi!!! |
#6 |
In the EL502 ( which is similar to EL504 ) this ring is connected to pin 9 .
#7 |
So that makes it a guard ring then I guess, to minimise dV/dt induced capacitive coupling to the exposed grid leads.
#8 |
Not only dV/dt, dc charges are also not allowed.
#9 |
mississippi, I don't quite understand the dc aspect you are referring to?
The characteristic of a sweep application that stands out from the crowd is the short high voltage flyback transient - which to my mind would be the reason for extra shielding, rather than the high duty cycle low voltage conduction period (which is perhaps the DC aspect you are referring to?) Ciao, Tim |
#10 |
Barkhausen oscillation or BK as we called it, manifested itself on some Televisions as a thin vertical stripe of white dots. We used to wrap a single shorted turn of tinned copper wire on the outside of the sweep output tube, take the loop down to a ground point, then adjust the wire loop up and down the tube for minimum interference. Later tubes came with the graphite ring already located inside it as it was becoming a common problem in its day with certain makes of Televisions. I doubt if BK would be a problem with normal audio usage though.
| Sweep tubes and G3 | rsumperl | Tubes / Valves | 3 | 5th October 2010 03:54 AM |
| Tubes: NOS Cetron JAN 6336B Graphite Plate Triodes | wildmonkeysects | Swap Meet | 0 | 22nd November 2009 06:43 PM |
| Do Sweep tubes Glow Blue? | wrenchone | Tubes / Valves | 26 | 20th July 2009 10:32 PM |
| Thoughts on horizontal sweep tubes? | DaveCan | Tubes / Valves | 14 | 28th August 2008 09:24 PM |
| Page generated in 0.15071 seconds (62.86% PHP - 37.14% MySQL) with 11 queries |
