#21 |
Sorry about if mu post about the mu vs. gain,
was like a lesson. I didnt meant to patronize at all... ![]() just a few words about, i was not mark clear enough internal parameters values, in first picture. .
#22 |
With the same circuit parts, like on the SCH for the example,
You can always expect that the stage gain will gravitate to the mu of tube in point CCS, L load, R load, Transformer Rload value 1:1 load with that order close to the mu of the tube ![]() . But that is not from the first importance, more is that the sound result is different and everyone should pick the topology according to personal taste and accessibility for the needed parts and power supply for. . I will try to put together some results of theese 4 different load types for this 6N6P circuit.
#23 |
And Yes, Your measurements are right, the mu and gain are little bit smaller then those given in datas, for those small triodes.
#24 |
This is simple CCS with BJTs for 6N6p circuit.
Gain is little higher then with common R load. And it is approximately the same value then load with L (choke) No 5th harmonic, and little bit lower noise floor. Amount of current is changing bt R I set and it is good to be the higher value for the start. for example 100 ohm. This is to be established in real circuit with real elements. C from b-c is for cut the bandwidth from the upper side and it is optional. Heat sink atached to MJE350... ![]() .
#25 |
Hi Zoran/all,
Have you actually constructed this. Iam keen to build a tube pre-amp. Do let me know how this sounded. Do you have a circuit for the power supply and voltages at the various points in the circuit for testing? Iam looking at a powersupply at http://www.gyraf.dk/gy_pd/g9/g9_sch.gif Regards Vinod |
#26 |
sch from #24 will work , even if I'll check some resistor values (LED models can be somewhat tricky regarding real life - I would use 5mm diffuse green ones , where you can expect 1V93 at 3-5mA through them )
regarding TL783 based series reg ...... I don't like it use any of HV shunt regs around , Salas made some , for my knowledge
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#27 | |
![]() Alex Cavalia put together a very nice sounding futterman inspired headamp/preamp with the 6n6p, the Bijou, that would be an interesting simulation (its weakness is also the operating point -cathode bias limiting the output.) I think a better cathode biasing mechanism and powersupply it could be a real firecracker. |
| Small tube amp based on 6N6P | jema | Tubes / Valves | 4 | 3rd October 2011 07:57 PM |
| 6n6p tube as output tube for small guitar amp | moonbird | Tubes / Valves | 28 | 7th September 2011 04:28 AM |
| cathode follower tube buffer using 6n6p | nightanole | Tubes / Valves | 30 | 30th March 2011 09:37 AM |
| Plate loaded 6N6P over SRPP 6N6P any day of the week... | Bas Horneman | Tubes / Valves | 14 | 26th February 2011 04:43 AM |
