6N6P tube - focus on
Old 5th December 2011, 03:02 PM   #11
Zoran is offline Zoran  Serbia
This is the circuit datas for Reactive load, like transformer with load of 2.4K.
For the solid range of bandwidth minimum inductance is about30 [Hy].
against maximum capacitance transferred at anode side of about 680 [pF],
which is not an unbearable question, but it is not so easy to achieve.
Cheers
Old 5th December 2011, 03:08 PM   #12
PDFs from Transformer Loaded 6N6P in line preamplifier circuit mode...
The datas showing even less distortion compare to low distortion with classic R load...
But the results are obtained with simple equivalent circuit, without core issues
or transfer ratio. Just total approximated values.
Old 5th December 2011, 03:10 PM   #13
I can check some results from the same operating point, with choke load,
and maybe with constant current source.
cheers
Old 5th December 2011, 03:12 PM   #14
From the previous datas I found another tube which could be loaded with the same
value like internal resistance. 6N30P russian tube
Old 5th December 2011, 05:34 PM   #15
artosalo is online now artosalo  Finland
artosalo's Avatar
I used the 6N6P Spice model you presented.
It gives mu=16.5 only. According the Soviet data sheet mu shoud be around 22.
My test circuit was CCS loaded common cathode amp.
Old 5th December 2011, 05:47 PM   #16
artosalo's Avatar
I checked the mu again from two different specifications and looked it from the anode curves. Those show some 17...18.5 indeed.
Old 6th December 2011, 06:44 AM   #17
Artosalo, mu is amplification factor of the tube
and it is the figure that it is not constant over the whole region.
mu is changing value with respect to point of operation.
And in the datashets mu is given like sort of average value.
Another thing is that mu, like amplification factor, and -A, stage gain is not the same thing at all.
amplification of the stage or stage gain or whatever You can call it
is the figure that is always smaller than the mu of the tube.
Mu of the tube is from static datas on paper.
Against the stage gain that represents tube in real dynamic environment,
in real circuit.
So mu and -A (negative mark before A is from phase reversal...)
are not the same figures, and should not be the same, -A is always lower than mu
in CSS mode and Choke loaded tube, -A is little bit closer to mu then in other load fashions.
Old 6th December 2011, 06:46 AM   #18
And You can find Yourself mu with the tubes datas of anode chrs.
from the graph. That method is the same for every classic style triode.
I post it at the first side.
mu is dUa/dUg in choosen point of operation.
Old 6th December 2011, 07:15 AM   #19
it is not so clear at the picture of settings from the first side.
So I magnify the point of operation and internal parameters values at the graph. I hope that it could be of help.
Old 6th December 2011, 08:08 AM   #20
artosalo's Avatar
Thanks for free lesson .
My point however was that is the mu of actual 6N6P tube that low. I had an image that 6N6P and ECC99 (JJ) would be similar (mu = some 22), but after checking some of my old measuring results too ( with CCS as anode load) it seems that mu is well below 20.
Would you please clarify what you mean.
6N6P tube - focus onHide this!Advertise here!
Small tube amp based on 6N6P jema Tubes / Valves 39 25th January 2017 04:30 PM
6n6p tube as output tube for small guitar amp moonbird Instruments and Amps 28 7th September 2011 04:28 AM
cathode follower tube buffer using 6n6p nightanole Tubes / Valves 30 30th March 2011 09:37 AM
Plate loaded 6N6P over SRPP 6N6P any day of the week... Bas Horneman Tubes / Valves 14 26th February 2011 04:43 AM
